963
steve switzer
Beginner
FHRP localization failure involving multi homing
Hi All
We currently have an issue out with our cisco support which we are awaiting a reply on..
If anyone has had anything similar it would be a great help if you could share with us.
We have two locations each with 2 Nexus 7k running IOS 6.2(2) using HRSP for redundancy.
We are trying to run an OTV vdc between the two locations .
In order to stop the local hsrp being broadcast between the two locations we have set an ACL
on the OTV vdc.
However this does not appear to be working as we can see the HSRP broadcasting over the
otv vdc. Which is causing problems.
This is some of the configuration for the OTV VDC to block hsrp broadcasts ....
otv-isis default
  vpn Overlay10
    redistribute filter route-map (xxxx)
otv site-vlan xxxx
spanning-tree vlan x priority 61440
mac-list HSRP-vmac-deny seq 10 deny (mac addr)
route-map stop-HSRP permit 10
  match mac-list (list)
ip access-list HSRP_IP
  10 permit udp any 224.0.0.x/32 eq 1985
  20 permit udp any 224.0.0.x/32 eq 1985
mac access-list HSRP_VMAC
  10 permit (mac addr)any
  20 permit (mac addr) any
arp access-list HSRP_VMAC_ARP
  10 deny ip any mac (mac addr)
  20 deny ip any mac (mac addr)
  30 permit ip any mac any
vlan access-map HSRP_Localization 10
        match mac address HSRP_VMAC
        match ip address HSRP_IP
        action drop
vlan access-map HSRP_Localization 20
        match mac address ALL_MACs
        match ip address ALL_IPs
        action forward
vlan filter HSRP_Localization vlan-list x,x-x,x
Many thanks for your help in advance
Steve
12 REPLIES 12
jerry.bonner
Beginner
do you have any arp inspection configured?
ip arp inspection filter HSRP_VMAC_ARP <OTV_Extended_VLANs>
Well jerry we don’t have it enabled on the OTV SVI because we are not using DHCP on that VDC.
Do you mean to put it in the SVI vdc ?
What kind of broadcasts are you seeing bleed through? Any log messages? The arp inspection is to filter out gratuitous arps from HSRP gateways. I believe OTV will proxy these to the other DC and this is used to filter them out.
Hi Jerry
This is an example of what we are seeing ...
2014 Jul 13 00:23:42 Rea-N7K-FabricB-SVI_VDC %ARP-3-DUP_VADDR_SRC_IP:  arp [6628
]  Source address of packet received from 0000.0c07.acf1 on Vlan241(port-channel
31) is duplicate of local virtual ip, 10.xx.xx.xxx
2014 Jul 13 00:23:53 Rea-N7K-FabricB-SVI_VDC %ARP-3-DUP_VADDR_SRC_IP:  arp [6628
]  Source address of packet received from 0000.0c9f.f0f3 on Vlan243(port-channel
31) is duplicate of local virtual ip, 10.xx.xxx.xxx
yep, ok, those logs are consistent with this issue.
Take a look here starting on page 23 and apply the arp inspection to your OTV VDC :
http://www.cisco.com/c/dam/en/us/products/collateral/switches/nexus-7000-series-switches/guide_c07-728315.pdf
Thanks Jerry
That looks quite convincing having read the document
So we probably need the arp inspection commands on the OTV VDC
Steve
Let us know how it goes.
~jerry
Hi Jerry
No i am afraid it didnt work
Steve
hmm ok. I would run a
show otv arp-nd-cache
on the otv vdc in the dc being affected. Look for the mac addresses you mention, 0000.0c07.acf1 and 0000.0c9f.f0f3. If you see these addresses in the output, it means that otv edge is still seeing arp messages coming in from the other dc, which means arp inspection might not be setup properly in the other dc to filter these out.
You can check to see which edge the mac is coming from by running
sh otv route 0000.0c07.acf1 vlan 241
sh otv route 0000.0c07.acf1 vlan 243
~jerry
Hi Jerry
No joy i am afraid cannot see the mac addresses
when i input the show otv arp-nd-cache command
So no point running the sh otv route command
Thanks Anyway
Anymore ideas ?
Steve
I would run the show otv route commands anyway to ensure that the traffic is coming from the otv tunnels.
Incidentally we also have a case with TAC and they havent got a clue so dont feel  bad about it
Content for Community-Ad
