02-05-2014 08:04 AM - edited 03-01-2019 07:31 AM
if I have an 2 ACTIVE/ACTIVE Data Centers with all the storage replicated in both Data Centers, how the hosts on the HQ know which Data Center to go?
1- In case my DCI is Layer 2
2- In case my DCI is Layer 3
Which are the technologies involved in each case so the HOST knows where to go in an ACTIVE/ACTIVE DC?
Thank you very much for your help.
J
Solved! Go to Solution.
02-06-2014 06:26 AM
Hi Jordi
You many need to consider Virtualalized workload Mobility or LISP
Look at below document
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/DCI/4.0/EMC/EMC_2.html
Sandip
02-06-2014 06:26 AM
Hi Jordi
Sandip
02-06-2014 06:31 AM
Thanks Sandip for the document.
J
