how can i config ASR 1006 as a vxlan vtep and using layer 3 vrf connect to outside
fly
Level 2
Level 2
    I want to use ASR 1006 directly connect to SPINE as a bgp evpn VTEP and then expand internal same vrf to outside network .
    I found vxlan l3 support document
     https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/cether/configuration/xe-16/ce-xe-16-book/evpn-vxlan-l3.html
    in vxlan internal ,I config a vxlan vni 100001 and vrf test-a below different vtep(nexus 93)
    on asr 1006 I try to config same vrf test-a connect to outside network
   bgp evpn neighbor can established from asr 1006 to spine.
      but not success ,does anyone try this?
    there is no l3 vni can config on asr 1006
     there is no detail document, please help
     thank you!
Jeremy
0 Replies 0
