How to enable browser view through CMD in Cisco Prime 2.2
dipindavi
I had installed new Cisco prime 2.2
I had ssh to the prime ,how can i enable https/Browser view through command line .
Charles Hill
Generate a certificate and stop and start ncs.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/administrator/guide/PIAdminBook/config_server_settings.html#pgfId-1084298
Setting Up HTTPS Access to Prime Infrastructure
Generating and Applying Self-Signed Certificates
Use Prime Infrastructure to generate and apply self-signed certificates.
Step 1 Log in to Prime Infrastructure as explained in Connecting Via CLI. Do not enter “configure terminal” mode.
Step 2 Enter the following command to generate a new RSA key and self-signed certificate with domain information:
PIServer/admin# ncs key genkey –newdn
You will be prompted for the Distinguished Name (DN) fields for the certificate. It is important to specify the fully qualified domain name (FQDN) of the server as the domain name that will be used to access Prime Infrastructure.
Step 3 To make the certificate valid, restart Prime Infrastructure as explained in Restarting Prime Infrastructure.
To avoid login complaints, instruct users to add the self-signed certificate to their browsers’ trust stores when they next access the Prime Infrastructure login page.
Hope this helps,
Please rate helpful posts.
Thanks.
Is it possible to reset/recover ISE CLI password from ISE WebGUI? I am  able to get into web gui of ISE, but not able to login to its CLI. So  want to reset/recover ISE CLI password from its GUI.
