How to make the secondary Prime as Primary
faisalcis1
Hi Everyone,
I have a HA pair of Prime Infrastructure, recently i tried to change the role of Prime and secondary units for the sake of checking its working. As a result the Primary unit became secondary and the secondary unit became Primary. Some problem happened with the secondary unit and it is not working as Primary server. Now how can I manually change the role of previous Primary server back to the same.
Rick1776
Level 5
Level 5
This link should help you.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-0/administrator/guide/PIAdminBook.pdf
Look under Failover Scenario and Failback Scenario
