HX installer stucked at Starting
plp_pnlr
Hi!
Have you ever experienced in HX deployment, installer was stucked at starting. WE're currently adding a node in a cluster and We're using the same installer we used in creating the cluster. new node is the same as the existing nodes.
5 Replies 5
Gary Wong
You can try to reset it by going to https://$InstallerIP/api/reset. Alternatively, SSH to the Installer VM and `restart stDeploy`.  /var/log/springpath/springpath_validation.log may also point you in the right direction.
Already solved by TAC. solution is to breakdown the standard expansion workflow in UCSM + Hypervisor config and Deploy
So you selected the I know what I'm doing workflow?
Yes
