05-18-2021 05:38 AM
Can the ESXI version installed on a HX node be downgraded before it will be added to the cluster?
Solved! Go to Solution.
05-19-2021 04:40 AM
You can pick an available hx customized ESXi .ISO for reimaging the server with lower version.
Ideally, you want to get the new host to be as close a version as possible to the other existing nodes.
Checking https://software.cisco.com/download/home/286305544/type/286305994/release/4.0(2e) you'll notice there are 3 .ISOs currently: 6.5U3, 6.7U3, 6.0U3
Kirk...
05-19-2021 04:40 AM
Kirk...
