Hyperflex 'Cluster Upgrade failure' - 4.0.2e to 5.0.2b
I need your support:
I last Windows Upgrades Fail whitout showing any reason.
As the picture following shows.
Kirk J
Due to lack of specific error messages, I suggest you simply retry the upgrade, or open a TAC case, as it may require log analysis to determine upgrade failure cause.
Did you run the HX health checker script prior to upgrading?
https://www.cisco.com/c/en/us/support/docs/hyperconverged-infrastructure/hyperflex-hx-data-platform/214101-hypercheck-hyperflex-health-pre-upgr.html
Kirk...
Hi Kirk
Yes, I restarted the process the upgrade had the same results. Yes, I pass the health checker script.
Antonio
