HyperFlex Replication Network Config Failure
Networker_eg
I have replication Network config failure on 2 clusters
Cluster-1: Failed to post the Replication Network job
HX does not even touch UCSM or Vcenter , I am using HXDP 35.(2d)
Cluster-2: [137] : Configure Bandwidth on Nodes - Failure: Error: Failed to set replication DstQosBW - Error Message Replication 23000
HXDP : 3.5(2d)
Vcenter : 6.5U2
UCSM : 4.0()
Now this error is generated during replication configuration and config fail
Have anyone seen this before
Kirk J
Has either cluster been expanded prior to trying to establish the replication?
Kirk...
DC-1 : expanded with 8 compute-only node clusters
DC-2 : expenses with 3 compute-only
node clusters
is there any other way of adding compute-only node to the cluster ?
Carl Armstrong
We also received this error.  We were able to get around this error with just checking the box for override the MTU size and set it to 1500.  The documentation states the MTU for the replication traffic should be 1500, but we received the same error unless we hard set it here to 1500.
