02-24-2018 11:49 AM - edited 03-01-2019 08:44 AM
As title, if I have a manually configured VXLAN evpn fabric, will this get all imported fine into DCNM if I add the devices?
02-25-2018 12:33 AM
03-05-2018 04:15 PM
Are you are asking about importing with the ability to modify the individual VXLAN VRFs and VNIs to then push the modified configuration down to the device? If so, that ability I believe is in the works and is not available as of 10.4.2. At the moment however, just discovering the device will not remove any configuration unless you deliberately push a configuration change.
After discovering the VXLAN configured device, you will be able to see the different VRFs and VNIs.
