interface/Vpc error!
lmanavalan
i am try to troubleshoot the nexus interface issue
configured vPC and assigned 2 interface to the Port-channel but i am encountering the below mentioned error message
adminCfgChange
then
Type1incompartibility
Derek Zhang
From the error message, seems you are referring to a N5K vpc rather than N7K.
To check the Type1, you need to check the doc:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/operations/n5k_vpc_ops.html#wp424990
When a mismatch in Type 1 parameters occur, the following applies:
If a graceful consistency check is enabled (default), the primary switch keeps the vPC up while the secondary switch brings it down
If a graceful consistency check is disabled, both peer switches suspend VLANs on the vPC ports.
So adminCfgChange could be the consequece of the Type1 error based on your detail scenario.
You probably need to check the Type 1 mismatch first.
That link was useful
When i checked the vpc brief this is what is got
58     Po58        down*  failed      vpc port channel           -
                                      mis-config due to vpc
                                      links in the 2 switches
                                      connected to different
                                      partners
regards
LM
If you still have problem can you share the output for
show vpc consistancy-parameters global as well as for individual interfaces
with regards
Prasad K
                                      partners
regards
LM
I got that one once when the cablers had stuffed up the labels on the fibres used to link the Nexus7k's to the switch at the other end of the vPC - so I had one leg of the vpc connected to one downline switch, and the second leg (from the second Nexus) connected to a *different* downline switch.
Once I traced the cables and found out that there was, actually, a problem with the connections and got both legs of the vPC into the same downline switch, the vPC came up.
Darren
