IP Address Assignment for Cisco Switches and Nutanix
vanbrugh12345
Beginner
Beginner
Dear all,
I have a new project using Cisco 4500x as core switches and 2960x as access switches deployment, on the server & storage side, we will select Nutanix which will be connecting to the 4500x core switches. Now I need to planning IP address assignment, but I have no ideas how many IP address should be alloated to the Nutanix system.
Actually, I understand number of IP address needed depending how many VM(s) will be created on the Nutanix system. In general, there are about 30VM(s) will be created. I need the information how many vlan(s) will be needed e.g. iLO, heart-bit, VM-motion, FT ..... etc.
Is there any guideline I can refer to for the best practice design and implementation ?
Thanks & Regards,
Vanbrugh.
Hi Vanbrugh,
Normally to start , we plan the ip address allotement by subnetting the IP address subnet allotted for DC like 10.234.0.0/16 and subnet these range into multiple of /23,/22,/24,/21 based on quantity of VM's and requirment.
Its always a thumb rule to have 5 yrs growth consedring making ip address availble in the same subnet.
what we pan based on the infrastructure divide the subnet for ILO for /24 , Heart beat with /30 subnets and VM Motion /29 with server vlan based on VM requirement may be /24,/23,/22.
Hope it Helps..
-GI
Rate if it Helps..
Recognize Your Peers
