Is XFP-10G-MM-SR capable of communicating with SFP-10G-SR
TechDude
Subject says it all
Is XFP-10G-MM-SR capable of communicating with SFP-10G-SR module?
Hello Ethan,
Yes, you may conect a trasceiver XFP-10G-MM-SR in one side with a SFP-10G-SR in the other side. Both of them have the same specifications related to kind of fiber and speed, not sure about the maximum reach.
Regards.
Richard.
6 Replies 6
TechDude
Anyone have an answer to this one?
Hello Ethan,
Regards.
Richard.
Hi richbarb
Thanks for clearing the above question as I too was two-minded about the compatibility. I have another question I need to clear from my mind , does the XFP-10G-MM-SR support regular LC fiber patch cord? I will be connecting from "XFP-10G-MM-SR" to "SFP-10G-SR" . Please recommend a patch cord for this connection?
1) Yes.
2) You can use any multimode fiber cord (this impacts in the distance and transmission quality), preference use the OM4.
Regards.
thanks richbarb
I will only be using it with distance less than 10m so multimode should be suffice.
Yes. Get the information of SFP-10G-SR module to solve.
