issu upgrade procedure for NX-OS 5.2 to 6.2.12 on 7010 (redundent sup & chassis)
amardram123
Hi All,
I am planing to upgrade our redundent nexus 7010 having redundent sup1, currentely running 5.2 to 6.2.12.
Can any one share the procedure for upgrade plan via ISSU. Any detailed document will be good help :-)
is it advisable to do via ISSU or via normal procedure considering no downtime or minimum downtime but short change window.
thanks,
Amar
8 Replies 8
sean_evershed
Level 7
Level 7
See this link for the upgrade procedure:
http://www.cisco.com/c/en/us/support/switches/nexus-7000-series-switches/products-installation-guides-list.html
If it was me I would err on the side of caution and ask for a short change window just in case something unforseen happens during the upgrade.
Hey thanks Sean,
I was trying to find upgrade path ffrom 5.1.3 to 6.2.x but it doesn't give details. Document shows upgrade path from 4.2 to 5.2 & from 5.2 to 6.0..
I feel i need to upgrade twice if i have to upgrade from 5.1.x to 6.2.x
something like 5.1.x ==> 5.2.x ==> 6.2.x
and also prior to 5.2 ISSU doesn't support parallel upgrade..
thanks..
Amar
Hi Amar,
Did you complete this upgrade successfully via the 5.1.x ==> 5.2.x ==> 6.2.x path?
Kelly
unfortunately not yet due to pending approval.. but i have plan to follow below approach after discussion with TAC:
Recommended upgrade path:
5.1(3)  ==> 5.2(9)
5.2(9)==>6.2(8a)
6.2(8a) ==>6.2(12)
since i have Sup-1.. i will be using below image for upgrade.
System & kickstart Images :
Kick Start:
n7000-s1-kickstart.5.2.9.bin
n7000-s1-kickstart.6.2.8a.bin
n7000-s1-kickstart.6.2.12.bin
System Start:
n7000-s1-dk9.5.2.9.bin
n7000-s1-dk9.6.2.8a.bin
n7000-s1-dk9.6.2.12.bin
will share detail plan. only if it is successful :-)
Hi Amar,
Renjith.K.George
Hi Renjith,
We still not upgraded due to pending approvals.
Amar
Hi Renjith,
I successfully upgraded from 5.1.1 --> 5.2.5 --> 6.2.2a --> 6.2.8a --> 6.2.12 on a pair of 7010s.
Kelly
Hi Kelly
is there any problem during upgrade from 5.2.5 -> 6.2.2a ?
Fikri
