issu upgrade procedure for NX-OS 6.1(2) to 6.2.12 on 7009 redundant sup1
Hi All,
I am planning to do an upgrade on nexus 7009 using ISSU.The current version is 6.1(2) and we are planning to upgrade to 6.2(12).
Could appreciate if someone has got any documentation?
Ideally zero downtime is preffered.
Renjith
InayathUlla Sharieff
Netstar,
First you have to upgrade to the 6.2(8) then move to 6.2(12) for ISSUe.
Table 6 Supported Direct ISSU and ISSD Paths for the Cisco Nexus 7000 Series Chassis
Current Release
Releases That Support Direct ISSU to the Current Release
ISSD
NX-OS Release 6.2(14)
6.2(12),6.2(10),6.2(8a),
6.2(8b)
No Support
NX-OS Release 6.2(12)
6.2(10), 6.2.(8a),6.2(8b)
No Support
NX-OS Release 6.2(10)
6.2(8a),6.2(8b
Below is the link on how to do the same:-
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/release/notes/62_nx-os_release_note.html#pgfId-811992
Inayath
**Please do not forget to rate the post if helpfull***
