issue in ntp synchronization
jhsdc-it
unable to synchronization NTP in nexus 7k and nexus 5k
balaji.bandi
Can you post ntp configuration and logs which you see an issue. make sure you use right interface or vrf for ntp to sync.
also post below output :
Show version
show features
sh run | i ntp
show clock
show ntp peer-status
BB
Software
BIOS: version 3.1.0
kickstart: version 6.2(20)
system: version 6.2(20)
BIOS compile time: 02/27/2013
kickstart image file is: bootflash:///n7700-s2-kickstart.6.2.20.bin
kickstart compile time: 11/6/2017 0:00:00 [11/29/2017 14:10:20]
system image file is: bootflash:///n7700-s2-dk9.6.2.20.bin
system compile time: 11/6/2017 0:00:00 [11/29/2017 15:31:33]
show feature
Feature Name Instance State
bfd 1 disabled
bfd_app 1 disabled
bgp 1 disabled
cts 1 disabled
dhcp 1 disabled
dot1x 1 disabled
eigrp 1 disabled
eigrp 2 disabled
eigrp 3 disabled
eigrp 4 disabled
eigrp 5 disabled
eigrp 6 disabled
eigrp 7 disabled
eigrp 8 disabled
eigrp 9 disabled
eigrp 10 disabled
eigrp 11 disabled
eigrp 12 disabled
eigrp 13 disabled
eigrp 14 disabled
eigrp 15 disabled
eigrp 16 disabled
eth_port_sec 1 disabled
evc 1 disabled
evmed 1 disabled
glbp 1 disabled
hsrp_engine 1 enabled
interface-vlan 1 enabled
isis 1 disabled
isis 2 disabled
isis 3 disabled
isis 4 disabled
isis 5 disabled
isis 6 disabled
isis 7 disabled
isis 8 disabled
isis 9 disabled
isis 10 disabled
isis 11 disabled
isis 12 disabled
isis 13 disabled
isis 14 disabled
isis 15 disabled
isis 16 disabled
itd 1 disabled
lacp 1 enabled
ldap 1 disabled
lisp 1 disabled
lldp 1 disabled
msdp 1 disabled
mvrp 1 disabled
netflow 1 enabled
onep 1 disabled
ospf 1 disabled
ospf 2 disabled
ospf 3 disabled
ospf 4 disabled
ospf 5 disabled
ospf 6 disabled
ospf 7 disabled
ospf 8 disabled
ospf 9 disabled
ospf 10 disabled
ospf 11 disabled
ospf 12 disabled
ospf 13 disabled
ospf 14 disabled
ospf 15 disabled
ospf 16 disabled
ospfv3 1 disabled
ospfv3 2 disabled
ospfv3 3 disabled
ospfv3 4 disabled
ospfv3 5 disabled
ospfv3 6 disabled
ospfv3 7 disabled
ospfv3 8 disabled
ospfv3 9 disabled
ospfv3 10 disabled
ospfv3 11 disabled
ospfv3 12 disabled
ospfv3 13 disabled
ospfv3 14 disabled
ospfv3 15 disabled
ospfv3 16 disabled
otv 1 disabled
pbr 1 disabled
pim 1 disabled
pim6 1 disabled
poap 1 disabled
pong 1 disabled
private-vlan 1 disabled
privilege 1 disabled
ptp 1 disabled
rip 1 disabled
rip 2 disabled
rip 3 disabled
rip 4 disabled
rise 1 disabled
scheduler 1 enabled
scpServer 1 disabled
sftpServer 1 disabled
sla_responder 1 disabled
sla_sender 1 disabled
sshServer 1 enabled
tacacs 1 disabled
telnetServer 1 disabled
tunnel 1 disabled
udld 1 disabled
vpc 1 enabled
vrrp 1 disabled
vrrpv3 1 disabled
vtp 1 enabled
wccp 1 disabled
show run | i ntp
ntp server 10.92.185.1 use-vrf management
ntp server 10.92.185.2 prefer use-vrf management
ntp source-interface Vlan21
Total peers : 2
* - selected for sync, + - peer mode(active),
- - peer mode(passive), = - polled in client mode
remote local st poll reach delay vrf
=10.92.185.1 10.92.185.253 1 64 377 0.00385 management
=10.92.185.2 10.92.185.253 2 64 377 0.00432 management
seems to be ok, what is the issue  you seeing ?
have you set the "clock protocol ntp"
i forgot to ask you, check the association also
show ntp association
BB
