Community Helping Community
471
Beginner
LISP Map Server Location
if you have 2 ACTIVE/ACTIVE DCs through dark fiber and your WAN is connected to an MPLS cloud where hundreds of offices are also attached, Where would you put the LISP MAP server?
As far as I understood the LISP MAP server could be a router, so would you configure the LISP MAP Server at the WAN Edge routers of the HQ's, or at the WAN Edge Routers of the 2 DCs in order to be closer of the VMs?
Thanks a lot for the help.
J
Content for Community-Ad
FusionCharts will render here
