04-11-2018 02:59 AM - edited 03-01-2019 08:45 AM
Dear Community,
I'd like to ask about device behavior when it reports every second:
%-SLOT1-5-BCM_L2_LEARN_DISABLE: MAC Learning Disabled unit=0
%-SLOT1-5-BCM_L2_LEARN_ENABLE: MAC Learning Enabled unit=0
02-19-2019 10:42 AM
Dear Piotr,
This the answer i received from a Cisco TAC engineer regarding the same question in 2017.
As far as the MAC learning is concerned, you can ignore those messages about the learning being enabled/disabled. Truly, to an NDB switch, the source MAC addresses will very easily appear to be moving rapidly between multiple source interfaces, as the same traffic SPANned at different points in the production network is fed to multiple source interfaces on an NDB switch. Ideally, we would disable the MAC address learning right away; unfortunately, the „mac-learn disable“ command on the N9300 platform is not available in 7.0(3)I4(6).
See Peter Paluchs message here: https://community.cisco.com/t5/switching/cannot-find-reference-for-this-message-seen-in-log-on-nexus-9508/td-p/2697030
12-10-2019 12:26 PM
the command "mac-learn disable" is available at 9.2.2 but does it cause flooding frames everywhere? Of course they would be blocked because of "switchport block unicast/multicast" in outbound direction. So what does it do actually?
Thx, Tomas
