12-07-2013 09:35 AM - edited 03-01-2019 07:28 AM
I have M1 48-port RJ-45 module and F2e 48-port SFP module in a 7K chassis. I like to have the ports from the two modules in the same OTV VDC (M1 ports for join interface and F2e ports for internal interface). Is NX-OS 6.2 the minimum to support M1 and F2e in the same VDC?
Solved! Go to Solution.
12-07-2013 11:39 PM
Yes, you need 6.2(2) release to support F2e and M1 in same VDC
Sandip
12-07-2013 11:39 PM
Sandip
