10-18-2010 05:06 PM - edited 03-01-2019 06:52 AM
do you know how many session can I configure into a nexus 700, because in this moment I only have two monitor session in different context, and the problem is that i can not configure another one into another context, I add the file with the configuration.
Solved! Go to Solution.
10-20-2010 10:55 AM
Hi Phillip,
Thank you so much for your help, I understood the reason I can not configure another one.
10-19-2010 07:07 AM
Hi Cesar,
Only two SPAN sessions can be active at the same time across all VDCs.
"Although you can define up to 18 SPAN sessions, only two SPAN sessions can be running simultaneously. You can shut down an unused SPAN session"
/Phil
10-20-2010 10:55 AM
Hi Phillip,
