monitor in nexus 7k version 4.2(4)
COST89010
Beginner
Beginner
do you know how many session can I configure into a nexus 700, because in this moment I only have two monitor session in different context, and the problem is that i can not configure another one into another context, I add the file with the configuration.
Hi Phillip,
Thank you so much for your help, I understood the reason I can not configure another one.
phiharri
Beginner
Beginner
Hi Cesar,
Only two SPAN sessions can be active at the same time across all VDCs.
"Although you can define up to 18 SPAN sessions,  only two SPAN sessions can be running simultaneously. You can shut down  an unused SPAN session"
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/system_management/configuration/guide/sm_14span.html#wp1239556
/Phil
Hi Phillip,
