07-24-2014 03:19 PM - edited 03-01-2019 07:37 AM
Hi All,
Having a big problem for us right now and appreciate very much any assistance as soon as possible!
Have a Nexus5548 Software 5.1(3)N2(1c) and installing a L3 card N55-M160L3-V2
The problem is that when connecting the SFP to an interface it says Layer 3 not ready!
The show module shows Hw not supported!
According to every documentation that I can find the card is compatible with both HW and SW, so what’s the problem?
interface Ethernet1/32
ip address x.x.x.x/30
N5K# sh int e1/32 status
Port Name Status Vlan Duplex Speed Type
Eth1/32 CONEXION HACIA N5K unknown e routed full 10G 10Gbase-LR
N5K# sh int e1/32 brief
Ethernet VLAN Type Mode Status Reason Speed Por
t
Interface Ch
Eth1/32 -- eth routed down L3 not ready 10G(D) --
N5K# sh module
Mod Ports Module-Type Model Status
1 32 O2 32X10GE/Modular Universal Pla N5K-C5548UP-SUP active *
2 0 O2 GEM with L3 ASIC N55-M160L3-V2 Hw not suppo
rted
3 0 O2 Non L3 Daughter Card N55-DL2 ok
Mod Sw Hw World-Wide-Name(s) (WWN)
07-24-2014 04:32 PM
Seems like we have the Nexus5596 card in the 5548 chassis.
We have the following licenses:
LAN_BASE_SERVICES_PKG
LAN_ENTERPRISE_SERVICES_PKG
Is the 5548UP nothing but a layer 2 switch without the L3 card? I mean even having those licenses installed and the NX-OS allowing to configure dynamic and static routing features?
07-24-2014 10:42 PM
Both models use the same daughter card. The problem is that you're running an outdated NX-OS version; the V2 requires 5.2(1)N1(1b) and later. Check the N5k datasheet.
07-25-2014 01:16 AM
I might not be interpreting the information correctly.
This is what I see from the data sheet and CCW.
The N55-D160L3-V2 is the L3 daughter, v2 card for the Nexus 5548
The N55-M160L3-V2 is the L3 expansion, v2 module for the Nexus 5596
You're saying the N55-M160L3-V2 will work on the 5548 if upgrading to 5.2(1)N1(1b) or later?
I will definitely give it a try.
07-25-2014 01:24 AM
Oops sorry, you're right about the different hardware; but I'm sure about the NX-OS version.
07-25-2014 01:30 AM
Thank you my friend. Would you happen to know if the N5k is a L2 switch only if missing the L3 card or module?
The reason I ask is that we installed the Enterprise license, and I can configure routing protocols or static routes and pretty much every L3 feature, but it does not work.
07-25-2014 02:09 AM
Yes, it only does switching then. Btw, the routing license in only needed if you want to use
Check Table 5 in this document.
