N5k96UP connected to 6509 no VSS over 1GB
Julian Geisler
Beginner
Beginner
Hi there,
i have the advantage to connect 2 N5k Switches on 2 6500 without VSS over 1GB Ports (Portchannel)
I configured LACP on the port-channel interfaces, and all interfaces on the 5ks facing down to the 65 in one Port-Channel and one vPC.
Is this the right way for this issue, ore dose i need to configure different port-channels and different vPCs on the 5ks?
Now, all Ports facing to 6500b are Suspended on N5ka and N5kb.
N5ka# sh port-channel summ
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
Group Port-       Type     Protocol  Member Ports
      Channel
10    Po10(SU)    Eth      LACP      Eth1/43(s)   Eth1/44(s)   Eth1/45(P)
                                     Eth1/46(P)   Eth2/13(s)   Eth2/14(s)
                                     Eth2/15(P)   Eth2/16(P)
N5kb# sh port-channel summ
      Channel
10    Po10(SU)    Eth      LACP      Eth1/43(P)   Eth1/44(P)   Eth1/45(s)
                                     Eth1/46(s)   Eth2/13(P)   Eth2/14(P)
                                     Eth2/15(s)   Eth2/16(s)
6500a#
interface GigabitEthernet2/17
description to N5ka
no ip address
switchport
switchport trunk allowed vlan 64
switchport mode trunk
switchport nonegotiate
channel-group 10 mode active
interface GigabitEthernet2/18
description to N5ka
no ip address
switchport
interface GigabitEthernet2/19
description to N5ka
no ip address
switchport
interface GigabitEthernet2/20
description to N5ka
no ip address
switchport
interface GigabitEthernet2/21
description N5kb
no ip address
switchport
interface GigabitEthernet2/22
description N5kb
no ip address
switchport
interface GigabitEthernet2/23
description N5Kb
no ip address
switchport
interface GigabitEthernet2/24
descriptionN5kb
no ip address
switchport
interface Port-channel10
description Po10 N5ka and N5kb
no ip address
switchport
6500b#
description to N5kb
no ip address
switchport
description to N5kb
no ip address
switchport
description to N5kb
no ip address
switchport
description to N5kb
no ip address
switchport
description N5ka
no ip address
switchport
description N5ka
no ip address
switchport
description N5Ka
no ip address
switchport
descriptionN5ka
no ip address
switchport
description Po10 N5kb and N5ka
no ip address
switchport
N5ka:
vpc domain 99
  role priority 1000
  peer-keepalive destination xxxxx
interface port-channel10
  description i=po10 Eth1/43 - 46, Eth2/13 - 16 6500a, 6500b Uplink VLAN64 vPC10
  vpc 10
  spanning-tree port type network
interface Ethernet1/43
  description i=Eth1/43 6500
  speed 1000
  udld aggressive
interface Ethernet1/44
  description i=Eth1/44 6500
  speed 1000
  udld aggressive
interface Ethernet1/45
  description i=Eth1/45 6500
  speed 1000
  udld aggressive
interface Ethernet1/46
  description i=Eth1/46 6500
  speed 1000
  udld aggressive
interface Ethernet1/47
  description i=e1/47 vPCpeerLink-Domain99
  udld aggressive
  channel-group 99
interface Ethernet1/48
  description i=e1/48 vPCpeerLink-Domain99
  udld aggressive
  channel-group 99
interface Ethernet2/13
  description i=Eth2/13 6500
  speed 1000
  udld aggressive
interface Ethernet2/14
  description i=Eth2/14 6500
  speed 1000
  udld aggressive
interface Ethernet2/15
  description i=Eth2/15 6500
  speed 1000
  udld aggressive
interface Ethernet2/16
  description i=Eth2/16 6500
  speed 1000
  udld aggressive
N5kb
  speed 1000
  udld aggressive
  speed 1000
  udld aggressive
  speed 1000
  udld aggressive
  speed 1000
  udld aggressive
  description i=e1/47 u=e1/47 t=vPCpeerLink-Domain99
  channel-group 99
  description i=e1/48  u=e1/48 t=vPCpeerLink-Domain99
  udld aggressive
  channel-group 99
  speed 1000
  udld aggressive
  speed 1000
  udld aggressive
  speed 1000
  udld aggressive
  speed 1000
  udld aggressive
11 Replies 11
nkarpysh
DO you have a peer-link and keepalive link between N5k? Does it work fine?
Nik
HTH,
Niko
Hi Nik,
yes, vpc peer-link & keepalive is established and working.
Hi Julian,
Can you please collect these outputs to check:
show vpc brief
show log log | i SUSPENDED
Show vpc consis global
Show vpc consis int po10
Nik
HTH,
Niko
Hi Nik,
here we go.
g6-nex# sh vpc brief
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 99
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : success
vPC role                        : secondary
Number of vPCs configured       : 98
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po99   up     1,64,1950,1972
vPC status
id     Port        Status Consistency Reason                     Active vlans
10     Po10        up     success     success                    64
11     Po11        down*  success     success                    -
1001   Po1001      up     success     success                    64
1002   Po1002      up     success     success                    64
1003   Po1003      up     success     success                    64
1004   Po1004      up     success     success                    64
1005   Po1005      up     success     success                    64
1006   Po1006      up     success     success                    64
1007   Po1007      up     success     success                    64
1008   Po1008      up     success     success                    64
1009   Po1009      up     success     success                    64
1010   Po1010      up     success     success                    64
1011   Po1011      up     success     success                    64
g6-nex# sh log log | i SUSPENDED
2011 Oct 31 14:33:29 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/16: Ethernet2/16 is suspended
2011 Oct 31 14:33:29 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/15: Ethernet2/15 is suspended
2011 Oct 31 14:33:29 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/46: Ethernet1/46 is suspended
2011 Oct 31 14:33:29 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/45: Ethernet1/45 is suspended
2011 Oct 31 14:38:34 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/46: Ethernet1/46 is suspended
2011 Oct 31 14:38:34 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/16: Ethernet2/16 is suspended
2011 Oct 31 14:38:34 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/15: Ethernet2/15 is suspended
2011 Oct 31 14:38:34 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/45: Ethernet1/45 is suspended
2011 Oct 31 15:00:44 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/44: Ethernet1/44 is suspended
2011 Oct 31 15:00:44 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/14: Ethernet2/14 is suspended
2011 Oct 31 15:00:44 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/13: Ethernet2/13 is suspended
2011 Oct 31 15:00:44 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/43: Ethernet1/43 is suspended
2011 Oct 31 15:03:29 g6-nex %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 64 on Interface port-channel10 are being suspended. (Reason: Peer does not have corres
ponding vPC)
2011 Oct 31 16:33:40 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/46: Ethernet1/46 is suspended
2011 Oct 31 16:33:40 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/45: Ethernet1/45 is suspended
2011 Oct 31 16:33:40 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/16: Ethernet2/16 is suspended
2011 Oct 31 16:33:40 g6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/15: Ethernet2/15 is suspended
g6-nex# sh vpc consis global
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
QoS                         2     ([], [], [], [], [],   ([], [], [], [], [],
Network QoS (MTU)           2     (1538, 0, 0, 0, 0, 0)  (1538, 0, 0, 0, 0, 0)
Network Qos (Pause)         2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Input Queuing (Bandwidth)   2     (100, 0, 0, 0, 0, 0)   (100, 0, 0, 0, 0, 0)
Input Queuing (Absolute     2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Priority)
Output Queuing (Bandwidth)  2     (100, 0, 0, 0, 0, 0)   (100, 0, 0, 0, 0, 0)
Output Queuing (Absolute    2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Priority)
STP Mode                    1     Rapid-PVST             Rapid-PVST
STP Disabled                1     None                   None
STP MST Region Name         1     ""                     ""
STP MST Region Revision     1     0                      0
STP MST Region Instance to  1
VLAN Mapping
STP Loopguard               1     Disabled               Disabled
STP Bridge Assurance        1     Enabled                Enabled
STP Port Type, Edge         1     Normal, Disabled,      Normal, Disabled,
BPDUFilter, Edge BPDUGuard        Disabled               Disabled
STP MST Simulate PVST       1     Enabled                Enabled
Allowed VLANs               -     1,64,1950,1972         1,64,1950,1972
Local suspended VLANs       -     -                      -
g6-nex# sh vpc consis int po10
    Legend:
Shut Lan                    1     No                     No
STP Port Type               1     Network Port           Network Port
STP Port Guard              1     None                   None
STP MST Simulate PVST       1     Default                Default
mode                        1     active                 active
Speed                       1     1000 Mb/s              1000 Mb/s
Duplex                      1     full                   full
Port Mode                   1     trunk                  trunk
Native Vlan                 1     1                      1
MTU                         1     1500                   1500
Admin port mode             1
lag-id                      1     [(7f9b,                [(7f9b,
                                  0-23-4-ee-be-63, 800a, 0-23-4-ee-be-63, 800a,
                                   0, 0), (8000,          0, 0), (8000,
                                  0-1e-4a-b7-d7-0, a, 0, 0-1e-4a-b7-d7-0, a, 0,
                                   0)]                    0)]
Allowed VLANs               -     64                     64
_______________________________________________________________________________________
z6-nex# sh vpc brief
Legend:
vPC domain id                   : 99
vPC role                        : primary
vPC status
11     Po11        down*  failed      Consistency Check Not      -
                                      Performed
1012   Po1012      up     success     success                    64
1013   Po1013      down*  success     success                    -
1014   Po1014      down*  success     success                    -
1015   Po1015      down*  success     success                    -
1016   Po1016      down*  success     success                    -
1101   Po1101      up     success     success                    64
1102   Po1102      up     success     success                    64
1103   Po1103      up     success     success                    64
1104   Po1104      up     success     success                    64
1105   Po1105      up     success     success                    64
1106   Po1106      up     success     success                    64
1107   Po1107      up     success     success                    64
1108   Po1108      up     success     success                    64
1109   Po1109      up     success     success                    64
1110   Po1110      up     success     success                    64
z6-nex# sh log log | i SUSPENDED
2011 Oct 31 12:39:08 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: port-channel99: port-channel99 is suspended
2011 Oct 31 12:39:08 z6-nex %ETH_PORT_CHANNEL-5-IF_DOWN_SUSPENDED_BY_SPEED: Interface Ethernet1/45 is down (Suspended due to incompatible speed
2011 Oct 31 14:33:30 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/14: Ethernet2/14 is suspended
2011 Oct 31 14:33:30 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/13: Ethernet2/13 is suspended
2011 Oct 31 14:33:30 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/44: Ethernet1/44 is suspended
2011 Oct 31 14:33:30 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/43: Ethernet1/43 is suspended
2011 Oct 31 14:38:34 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/44: Ethernet1/44 is suspended
2011 Oct 31 14:38:34 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/43: Ethernet1/43 is suspended
2011 Oct 31 14:38:34 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/14: Ethernet2/14 is suspended
2011 Oct 31 14:38:34 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/13: Ethernet2/13 is suspended
2011 Oct 31 15:00:45 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/46: Ethernet1/46 is suspended
2011 Oct 31 15:00:45 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/15: Ethernet2/15 is suspended
2011 Oct 31 15:00:45 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/45: Ethernet1/45 is suspended
2011 Oct 31 15:03:33 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/15: Ethernet2/15 is suspended
2011 Oct 31 15:03:33 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/46: Ethernet1/46 is suspended
2011 Oct 31 15:03:33 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/45: Ethernet1/45 is suspended
2011 Oct 31 15:03:42 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/15: Ethernet2/15 is suspended
2011 Oct 31 15:03:42 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/46: Ethernet1/46 is suspended
2011 Oct 31 15:03:42 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/45: Ethernet1/45 is suspended
2011 Oct 31 15:19:16 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/16: Ethernet2/16 is suspended
2011 Oct 31 16:33:40 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/14: Ethernet2/14 is suspended
2011 Oct 31 16:33:40 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet2/13: Ethernet2/13 is suspended
2011 Oct 31 16:33:40 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/44: Ethernet1/44 is suspended
2011 Oct 31 16:33:40 z6-nex %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/43: Ethernet1/43 is suspended
z6-nex# sh vpc consis glo
    Legend:
Priority)
Priority)
VLAN Mapping
z6-nex#
z6-nex# sh vpc consis int po10
    Legend:
Shut Lan                    1     No                     No
                                   0)]                    0)]
Duplex                      1     full                   full
Native Vlan                 1     1                      1
MTU                         1     1500                   1500
Admin port mode             1
z6-nex#
I see this as reason for ports being initially suspended:
ponding vPC)
Can it be that one side was not configured as VPC initially?
And I see Po10 is currently UP. Did you fix it somehow?
Nik
HTH,
Niko
Hi Nik,
no, i don´t change anything on the config. the ports are still in suspended state.
But, when i shutdown the activ ports on the 65x pointing to 5k, the suspended ports become active.
Hi Julian,
Did you try mode On on the port-channel ports and if possible to try it? By this we can see if the problem is with LACP to debug it then.
HTH,
Niko
Hi Nik,
mode on couses a loop and no traffic will be transmitted over the uplink interfaces.
LUis,
Can you please attach full configs of the Nexus switches to see if I'm not missing smth. Also did you try to limit number of ports within port-channels to one on each side and then continue to add more ports?
Nik
HTH,
Niko
!Command: show running-config
!Time: Thu Nov 17 15:31:23 2011
version 5.0(3)N2(2)
no feature telnet
no telnet server enable
cfs eth distribute
feature udld
feature lacp
feature vpc
feature lldp
feature fex
username xxx password 5 xxx role network-admin
ip domain-lookup
radius-server key 7 xxxx
radius-server timeout 3
radius-server retransmit 2
radius-server host 10.10.8.53 auth-port 1645 acct-port 1646 authentication accounting
aaa group server radius RADAuth
    server 10.10.8.53
    use-vrf management
    source-interface mgmt0
hostname g6-nex
logging event link-status default
ip access-list SNMP
  10 permit ip 10.10.3.0/24 any
  20 permit ip 10.10.8.0/24 any
  30 deny ip any any
ip access-list SSHlogin
  30 deny ip any any
class-map type qos class-fcoe
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
fex 104
  pinning max-links 8
  description "FEX0104"
fex 105
  pinning max-links 8
  description "FEX0105"
fex 106
  pinning max-links 4
  description "FEX0106"
fex 107
  pinning max-links 4
  description "FEX0107"
snmp-server location  xxx
snmp-server host 10.10.8.14 traps version 2c g6-nex
snmp-server host 10.10.8.14 use-vrf management
snmp-server host 10.10.8.13 traps version 2c z6-nex
snmp-server host 10.10.8.13 use-vrf management
snmp-server enable traps callhome event-notify
snmp-server enable traps callhome smtp-send-fail
snmp-server enable traps cfs state-change-notif
snmp-server enable traps cfs merge-failure
snmp-server enable traps aaa server-state-change
snmp-server enable traps zone unsupp-mem
snmp-server enable traps upgrade UpgradeOpNotifyOnCompletion
snmp-server enable traps upgrade UpgradeJobStatusNotify
snmp-server enable traps feature-control FeatureOpStatusChange
snmp-server enable traps sysmgr cseFailSwCoreNotifyExtended
snmp-server enable traps config ccmCLIRunningConfigChanged
snmp-server enable traps snmp authentication
snmp-server enable traps vtp notifs
snmp-server enable traps vtp vlancreate
snmp-server enable traps vtp vlandelete
snmp-server enable traps poe portonoff
snmp-server enable traps poe pwrusageon
snmp-server enable traps poe pwrusageoff
snmp-server enable traps poe police
snmp-server community xxx group network-operator
snmp-server community xxx group network-admin
snmp-server community xxx use-acl SNMP
ntp server 10.10.8.53 use-vrf management
aaa authentication login default group RADAuth
aaa authentication login console group RADAuth
aaa accounting default group RADAuth
vrf context management
  ip route 0.0.0.0/0 10.10.3.202
vlan 1
vlan 64
  name BDRLAN_064_Server
vlan 1950
  name BDRLAN_1950_VMKERNEL
vlan 1972
  name BDRLAN_1972_SMN-Srv
vpc domain 99
  peer-keepalive destination 10.10.3.130
  description i=po10 Eth1/43 - 46, Eth2/13 - 16 s=z6-c65, g6-c65 t=Uplink VLAN64 vPC10
  vpc 10
interface port-channel11
  vpc 11
interface port-channel99
  description i=po99 e1/47 e1/48 s=z6-nex u=po99 t=vPCpeerLink
  vpc peer-link
interface port-channel1001
  description i=po1001 Eth104/1/1 - Eth100/1/1 t=Port-Channel
  vpc 1001
  switchport access vlan 64
interface port-channel1002
  description i=po1002 Eth104/1/2 - Eth100/1/2 t=Port-Channel
  vpc 1002
interface port-channel1003
  description i=po1003 Eth104/1/3 - Eth100/1/3 t=Port-Channel
  vpc 1003
interface port-channel1004
  description i=po1004 Eth104/1/4 - Eth100/1/4 t=Port-Channel
  vpc 1004
interface port-channel1005
  description i=po1005 Eth104/1/5 - Eth100/1/5 t=Port-Channel
  vpc 1005
interface port-channel1006
  description i=po1006 Eth104/1/6 - Eth100/1/6 t=Port-Channel
  vpc 1006
interface port-channel1007
  description i=po1007 Eth104/1/7 - Eth100/1/7 t=Port-Channel
  vpc 1007
interface port-channel1008
  description i=po1008 Eth104/1/8 - Eth100/1/8 t=Port-Channel
  vpc 1008
interface port-channel1009
  description i=po1009 Eth104/1/9 - Eth100/1/9 t=Port-Channel
  vpc 1009
interface port-channel1010
  description i=po1010 Eth104/1/10 - Eth100/1/10 t=Port-Channel
  vpc 1010
interface port-channel1011
  description i=po1011 Eth104/1/11 - Eth100/1/11 t=Port-Channel
  vpc 1011
interface port-channel1012
  description i=po1012 Eth104/1/12 - Eth100/1/12 t=Port-Channel
  vpc 1012
interface port-channel1013
  description i=po1013 Eth104/1/13 - Eth100/1/13 t=Port-Channel
  vpc 1013
interface port-channel1014
  description i=po1014 Eth104/1/14 - Eth100/1/14 t=Port-Channel
  vpc 1014
interface port-channel1015
  description i=po1015 Eth104/1/15 - Eth100/1/15 t=Port-Channel
  vpc 1015
interface port-channel1016
  description i=po1016 Eth104/1/16 - Eth100/1/16 t=Port-Channel
  vpc 1016
interface port-channel1101
  description i=po1101 Eth105/1/1 - Eth101/1/1 t=Port-Channel
  vpc 1101
interface port-channel1102
  description i=po1102 Eth105/1/2 - Eth101/1/2 t=Port-Channel
  vpc 1102
interface port-channel1103
  description i=po1103 Eth105/1/3 - Eth101/1/3 t=Port-Channel
  vpc 1103
interface port-channel1104
  description i=po1104 Eth105/1/4 - Eth101/1/4 t=Port-Channel
  vpc 1104
interface port-channel1105
  description i=po1105 Eth105/1/5 - Eth101/1/5 t=Port-Channel
  vpc 1105
interface port-channel1106
  description i=po1106 Eth105/1/6 - Eth101/1/6 t=Port-Channel
  vpc 1106
interface port-channel1107
  description i=po1107 Eth105/1/7 - Eth101/1/7 t=Port-Channel
  vpc 1107
interface port-channel1108
  description i=po1108 Eth105/1/8 - Eth101/1/8 t=Port-Channel
  vpc 1108
interface port-channel1109
  description i=po1109 Eth105/1/9 - Eth101/1/9 t=Port-Channel
  vpc 1109
interface port-channel1110
  description i=po1110 Eth105/1/10 - Eth101/1/10 t=Port-Channel
  vpc 1110
interface port-channel1111
  description i=po1111 Eth105/1/11 - Eth101/1/11 t=Port-Channel
  vpc 1111
interface port-channel1112
  description i=po1112 Eth105/1/12 - Eth101/1/12 t=Port-Channel
  vpc 1112
interface port-channel1113
  description i=po1113 Eth105/1/13 - Eth101/1/13 t=Port-Channel
  vpc 1113
interface port-channel1114
  description i=po1114 Eth105/1/14 - Eth101/1/14 t=Port-Channel
  vpc 1114
interface port-channel1115
  description i=po1115 Eth105/1/15 - Eth101/1/15 t=Port-Channel
  vpc 1115
interface port-channel1116
  description i=po1116 Eth105/1/16 - Eth101/1/16 t=Port-Channel
  vpc 1116
interface port-channel1201
  description i=po1201 Eth106/1/1 - Eth102/1/1 t=Port-Channel
  vpc 1201
  switchport access vlan 1972
interface port-channel1202
  description i=po1202 Eth106/1/2 - Eth102/1/2 t=Port-Channel
  vpc 1202
interface port-channel1203
  description i=po1203 Eth106/1/3 - Eth102/1/3 t=Port-Channel
  vpc 1203
interface port-channel1204
  description i=po1204 Eth106/1/4 - Eth102/1/4 t=Port-Channel
  vpc 1204
interface port-channel1205
  description i=po1205 Eth106/1/5 - Eth102/1/5 t=Port-Channel
  vpc 1205
interface port-channel1206
  description i=po1206 Eth106/1/6 - Eth102/1/6 t=Port-Channel
  vpc 1206
interface port-channel1207
  description i=po1207 Eth106/1/7 - Eth102/1/7 t=Port-Channel
  vpc 1207
interface port-channel1208
  description i=po1208 Eth106/1/8 - Eth102/1/8 t=Port-Channel
  vpc 1208
interface port-channel1209
  description i=po1209 Eth106/1/9 - Eth102/1/9 t=Port-Channel
  vpc 1209
interface port-channel1210
  description i=po1210 Eth106/1/10 - Eth102/1/10 t=Port-Channel
  vpc 1210
interface port-channel1211
  description i=po1211 Eth106/1/11 - Eth102/1/11 t=Port-Channel
  vpc 1211
interface port-channel1212
  description i=po1212 Eth106/1/12 - Eth102/1/12 t=Port-Channel
  vpc 1212
interface port-channel1213
  description i=po1213 Eth106/1/13 - Eth102/1/13 t=Port-Channel
  vpc 1213
interface port-channel1214
  description i=po1214 Eth106/1/14 - Eth102/1/14 t=Port-Channel
  vpc 1214
interface port-channel1215
  description i=po1215 Eth106/1/15 - Eth102/1/15 t=Port-Channel
  vpc 1215
interface port-channel1216
  description i=po1216 Eth106/1/16 - Eth102/1/16 t=Port-Channel
  vpc 1216
interface port-channel1217
  description i=po1217 Eth106/1/17 - Eth102/1/17 t=Port-Channel
  vpc 1217
  switchport access vlan 1950
interface port-channel1218
  description i=po1218 Eth106/1/18 - Eth102/1/18 t=Port-Channel
  vpc 1218
interface port-channel1219
  description i=po1219 Eth106/1/19 - Eth102/1/19 t=Port-Channel
  vpc 1219
interface port-channel1220
  description i=po1220 Eth106/1/20 - Eth102/1/20 t=Port-Channel
  vpc 1220
interface port-channel1221
  description i=po1221 Eth106/1/21 - Eth102/1/21 t=Port-Channel
  vpc 1221
interface port-channel1222
  description i=po1222 Eth106/1/22 - Eth102/1/22 t=Port-Channel
  vpc 1222
interface port-channel1223
  description i=po1223 Eth106/1/23 - Eth102/1/23 t=Port-Channel
  vpc 1223
interface port-channel1224
  description i=po1224 Eth106/1/24 - Eth102/1/24 t=Port-Channel
  vpc 1224
interface port-channel1225
  description i=po1225 Eth106/1/25 - Eth102/1/25 t=Port-Channel
  vpc 1225
interface port-channel1226
  description i=po1226 Eth106/1/26 - Eth102/1/26 t=Port-Channel
  vpc 1226
interface port-channel1227
  description i=po1227 Eth106/1/27 - Eth102/1/27 t=Port-Channel
  vpc 1227
[K
interface port-channel1228
  description i=po1228 Eth106/1/28 - Eth102/1/28 t=Port-Channel
  vpc 1228
interface port-channel1229
  description i=po1229 Eth106/1/29 - Eth102/1/29 t=Port-Channel
  vpc 1229
interface port-channel1230
  description i=po1230 Eth106/1/30 - Eth102/1/30 t=Port-Channel
  vpc 1230
interface port-channel1231
  description i=po1231 Eth106/1/31 - Eth102/1/31 t=Port-Channel
  vpc 1231
interface port-channel1232
  description i=po1232 Eth106/1/32 - Eth102/1/32 t=Port-Channel
  vpc 1232
interface port-channel1301
  description i=po1301 Eth107/1/1 - Eth103/1/1 t=Port-Channel
  vpc 1301
interface port-channel1302
  description i=po1302 Eth107/1/2 - Eth103/1/2 t=Port-Channel
  vpc 1302
interface port-channel1303
  description i=po1303 Eth107/1/3 - Eth103/1/3 t=Port-Channel
  vpc 1303
interface port-channel1304
  description i=po1304 Eth107/1/4 - Eth103/1/4 t=Port-Channel
  vpc 1304
interface port-channel1305
  description i=po1305 Eth107/1/5 - Eth103/1/5 t=Port-Channel
  vpc 1305
interface port-channel1306
  description i=po1306 Eth107/1/6 - Eth103/1/6 t=Port-Channel
  vpc 1306
interface port-channel1307
  description i=po1307 Eth107/1/7 - Eth103/1/7 t=Port-Channel
  vpc 1307
interface port-channel1308
  description i=po1308 Eth107/1/8 - Eth103/1/8 t=Port-Channel
  vpc 1308
interface port-channel1309
  description i=po1309 Eth107/1/9 - Eth103/1/9 t=Port-Channel
  vpc 1309
interface port-channel1310
  description i=po1310 Eth107/1/10 - Eth103/1/10 t=Port-Channel
  vpc 1310
interface port-channel1311
  description i=po1311 Eth107/1/11 - Eth103/1/11 t=Port-Channel
  vpc 1311
interface port-channel1312
  description i=po1312 Eth107/1/12 - Eth103/1/12 t=Port-Channel
  vpc 1312
interface port-channel1313
  description i=po1313 Eth107/1/13 - Eth103/1/13 t=Port-Channel
  vpc 1313
interface port-channel1314
  description i=po1314 Eth107/1/14 - Eth103/1/14 t=Port-Channel
  vpc 1314
interface port-channel1315
  description i=po1315 Eth107/1/15 - Eth103/1/15 t=Port-Channel
  vpc 1315
interface port-channel1316
  description i=po1316 Eth107/1/16 - Eth103/1/16 t=Port-Channel
  vpc 1316
interface port-channel1317
  description i=po1317 Eth107/1/17 - Eth103/1/17 t=Port-Channel
  vpc 1317
interface port-channel1318
  description i=po1318 Eth107/1/18 - Eth103/1/18 t=Port-Channel
  vpc 1318
interface port-channel1319
  description i=po1319 Eth107/1/19 - Eth103/1/19 t=Port-Channel
  vpc 1319
interface port-channel1320
  description i=po1320 Eth107/1/20 - Eth103/1/20 t=Port-Channel
  vpc 1320
interface port-channel1321
  description i=po1321 Eth107/1/21 - Eth103/1/21 t=Port-Channel
  vpc 1321
interface port-channel1322
  description i=po1322 Eth107/1/22 - Eth103/1/22 t=Port-Channel
  vpc 1322
interface port-channel1323
  description i=po1323 Eth107/1/23 - Eth103/1/23 t=Port-Channel
  vpc 1323
interface port-channel1324
  description i=po1324 Eth107/1/24 - Eth103/1/24 t=Port-Channel
  vpc 1324
interface port-channel1325
  description i=po1325 Eth107/1/25 - Eth103/1/25 t=Port-Channel
  vpc 1325
interface port-channel1326
  description i=po1326 Eth107/1/26 - Eth103/1/26 t=Port-Channel
  vpc 1326
interface port-channel1327
  description i=po1327 Eth107/1/27 - Eth103/1/27 t=Port-Channel
  vpc 1327
interface port-channel1328
  description i=po1328 Eth107/1/28 - Eth103/1/28 t=Port-Channel
  vpc 1328
interface port-channel1329
  description i=po1329 Eth107/1/29 - Eth103/1/29 t=Port-Channel
  vpc 1329
interface port-channel1330
  description i=po1330 Eth107/1/30 - Eth103/1/30 t=Port-Channel
  vpc 1330
interface port-channel1331
  description i=po1331 Eth107/1/31 - Eth103/1/31 t=Port-Channel
  vpc 1331
interface port-channel1332
  description i=po1332 Eth107/1/32 - Eth103/1/32 t=Port-Channel
  vpc 1332
interface Ethernet1/1
  description i=e1/01 s=FEX104-10GB t=FEX-Uplink
  switchport mode fex-fabric
  fex associate 104
interface Ethernet1/2
  description i=e1/02 s=FEX104-10GB t=FEX-Uplink
  fex associate 104
interface Ethernet1/3
  description i=e1/03 s=FEX104-10GB t=FEX-Uplink
  fex associate 104
  description i=e1/04 s=FEX104-10GB t=FEX-Uplink
  fex associate 104
interface Ethernet1/5
  description i=e1/05 s=FEX104-10GB t=FEX-Uplink
  fex associate 104
interface Ethernet1/6
  description i=e1/06 s=FEX104-10GB t=FEX-Uplink
  fex associate 104
interface Ethernet1/7
  description i=e1/07 s=FEX104-10GB t=FEX-Uplink
  fex associate 104
interface Ethernet1/8
  description i=e1/08 s=FEX104-10GB t=FEX-Uplink
  fex associate 104
interface Ethernet1/9
  description i=e1/09 s=FEX105-10GB t=FEX-Uplink
  fex associate 105
interface Ethernet1/10
  description i=e1/10 s=FEX105-10GB t=FEX-Uplink
  fex associate 105
interface Ethernet1/11
  description i=e1/11 s=FEX105-10GB t=FEX-Uplink
  fex associate 105
interface Ethernet1/12
  description i=e1/12 s=FEX105-10GB t=FEX-Uplink
  fex associate 105
interface Ethernet1/13
  description i=e1/13 s=FEX105-10GB t=FEX-Uplink
  fex associate 105
interface Ethernet1/14
  description i=e1/14 s=FEX105-10GB t=FEX-Uplink
  fex associate 105
interface Ethernet1/15
  description i=e1/15 s=FEX105-10GB t=FEX-Uplink
  fex associate 105
interface Ethernet1/16
  description i=e1/16 s=FEX105-10GB t=FEX-Uplink
  fex associate 105
interface Ethernet1/17
  description i=e1/17 s=FEX106-1GB t=FEX-Uplink
  fex associate 106
interface Ethernet1/18
  description i=e1/18 s=FEX106-1GB t=FEX-Uplink
  fex associate 106
interface Ethernet1/19
  description i=e1/19 s=FEX106-1GB t=FEX-Uplink
  fex associate 106
interface Ethernet1/20
  description i=e1/20 s=FEX106-1GB t=FEX-Uplink
  fex associate 106
interface Ethernet1/21
  description i=e1/21 s=FEX107-1GB t=FEX-Uplink
  fex associate 107
interface Ethernet1/22
  description i=e1/22 s=FEX107-1GB t=FEX-Uplink
  fex associate 107
interface Ethernet1/23
  description i=e1/23 s=FEX107-1GB t=FEX-Uplink
  fex associate 107
interface Ethernet1/24
  description i=e1/24 s=FEX107-1GB t=FEX-Uplink
  fex associate 107
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
interface Ethernet1/32
interface Ethernet1/33
interface Ethernet1/34
interface Ethernet1/35
interface Ethernet1/36
interface Ethernet1/37
interface Ethernet1/38
interface Ethernet1/39
interface Ethernet1/40
interface Ethernet1/41
  description i=e1/41 s=s6-4-smn1 gi1/0/52 v=1950,1972
  switchport trunk allowed vlan 1950,1972
  speed 1000
interface Ethernet1/42
  description i=Eth1/43 s=z6-c65 gi2/23 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth1/44 s=z6-c65 gi2/24 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth1/45 s=g6-c65 gi2/19 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth1/46 s=g6-c65 gi2/20 t=trunk v=64
  speed 1000
  udld aggressive
  description i=e1/47 s=z6-nex u=e1/47 t=vPCpeerLink-Domain99
  channel-group 99
  description i=e1/48 s=z6-nex u=e1/48 t=vPCpeerLink-Domain99
  udld aggressive
  channel-group 99
interface Ethernet2/2
interface Ethernet2/3
interface Ethernet2/4
interface Ethernet2/5
interface Ethernet2/6
interface Ethernet2/7
interface Ethernet2/8
interface Ethernet2/9
interface Ethernet2/10
interface Ethernet2/11
interface Ethernet2/12
  description i=Eth2/13 s=z6-c65 gi2/21 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth2/14 s=z6-c65 gi2/22 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth2/15 s=g6-c65 gi2/17 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth2/16 s=g6-c65 gi2/18 t=trunk v=64
  speed 1000
  udld aggressive
interface mgmt0
  ip address 10.10.3.131/24
interface Ethernet104/1/1
  description i=Eth104/1/1 h=ESX01a t=Port-Channel
  spanning-tree port type edge
  channel-group 1001
interface Ethernet104/1/2
  description i=Eth104/1/2 h=ESX02a t=Port-Channel
  channel-group 1002
interface Ethernet104/1/3
  description i=Eth104/1/3 h=ESX03a t=Port-Channel
  channel-group 1003
interface Ethernet104/1/4
  description i=Eth104/1/4 h=ESX04a t=Port-Channel
  channel-group 1004
interface Ethernet104/1/5
  description i=Eth104/1/5 h=ESX05a t=Port-Channel
  channel-group 1005
interface Ethernet104/1/6
  description i=Eth104/1/6 h=ESX06a t=Port-Channel
  channel-group 1006
interface Ethernet104/1/7
  description i=Eth104/1/7 h=ESX06a t=Port-Channel
  channel-group 1007
interface Ethernet104/1/8
  description i=Eth104/1/8 h=ESX09a t=Port-Channel
  channel-group 1008
interface Ethernet104/1/9
  description i=Eth104/1/9 h=ESX10a t=Port-Channel
  channel-group 1009
interface Ethernet104/1/10
  description i=Eth104/1/10 h=ESX11a t=Port-Channel
  channel-group 1010
interface Ethernet104/1/11
  description i=Eth104/1/11 h=ESX12a t=Port-Channel
  channel-group 1011
interface Ethernet104/1/12
  description i=Eth104/1/12 h=ESX13a t=Port-Channel
  channel-group 1012
interface Ethernet104/1/13
  description i=Eth104/1/13 h=ESX14a t=Port-Channel
  channel-group 1013
interface Ethernet104/1/14
  description i=Eth104/1/14 h=ESX15a t=Port-Channel
  channel-group 1014
interface Ethernet104/1/15
  description i=Eth104/1/15 h=ESX15a t=Port-Channel
  channel-group 1015
interface Ethernet104/1/16
  description i=Eth104/1/16 h=ESX16a t=Port-Channel
  channel-group 1016
interface Ethernet104/1/17
  shutdown
interface Ethernet104/1/18
  shutdown
interface Ethernet104/1/19
  shutdown
interface Ethernet104/1/20
  shutdown
interface Ethernet104/1/21
  shutdown
interface Ethernet104/1/22
  shutdown
interface Ethernet104/1/23
  shutdown
interface Ethernet104/1/24
  shutdown
interface Ethernet104/1/25
  shutdown
interface Ethernet104/1/26
  shutdown
interface Ethernet104/1/27
  shutdown
interface Ethernet104/1/28
  shutdown
interface Ethernet104/1/29
  shutdown
interface Ethernet104/1/30
  shutdown
interface Ethernet104/1/31
  shutdown
interface Ethernet104/1/32
  shutdown
interface Ethernet105/1/1
  description i=Eth105/1/1 h=ESX01b t=Port-Channel
  channel-group 1101
interface Ethernet105/1/2
  description i=Eth105/1/2 h=ESX02b t=Port-Channel
  channel-group 1102
interface Ethernet105/1/3
  description i=Eth105/1/3 h=ESX03b t=Port-Channel
  channel-group 1103
interface Ethernet105/1/4
  description i=Eth105/1/4 h=ESX04b t=Port-Channel
  channel-group 1104
interface Ethernet105/1/5
  description i=Eth105/1/5 h=ESX05b t=Port-Channel
  channel-group 1105
interface Ethernet105/1/6
  description i=Eth105/1/6 h=ESX06b t=Port-Channel
  channel-group 1106
interface Ethernet105/1/7
  description i=Eth105/1/7 h=ESX07b t=Port-Channel
  channel-group 1107
interface Ethernet105/1/8
  description i=Eth105/1/8 h=ESX08b t=Port-Channel
  channel-group 1108
interface Ethernet105/1/9
  description i=Eth105/1/9 h=ESX09b t=Port-Channel
  channel-group 1109
interface Ethernet105/1/10
  description i=Eth105/1/10 h=ESX10b t=Port-Channel
  channel-group 1110
interface Ethernet105/1/11
  description i=Eth105/1/11 h=ESX11b t=Port-Channel
  channel-group 1111
interface Ethernet105/1/12
  description i=Eth105/1/12 h=ESX12b t=Port-Channel
  channel-group 1112
interface Ethernet105/1/13
  description i=Eth105/1/13 h=ESX13b t=Port-Channel
  channel-group 1113
interface Ethernet105/1/14
  description i=Eth105/1/14 h=ESX14b t=Port-Channel
  channel-group 1114
interface Ethernet105/1/15
  description i=Eth105/1/15 h=ESX15b t=Port-Channel
  channel-group 1115
interface Ethernet105/1/16
  description i=Eth105/1/16 h=ESX16b t=Port-Channel
  channel-group 1116
interface Ethernet105/1/17
  shutdown
interface Ethernet105/1/18
  shutdown
interface Ethernet105/1/19
  shutdown
interface Ethernet105/1/20
  shutdown
interface Ethernet105/1/21
  shutdown
interface Ethernet105/1/22
  shutdown
interface Ethernet105/1/23
  shutdown
interface Ethernet105/1/24
  shutdown
interface Ethernet105/1/25
  shutdown
interface Ethernet105/1/26
  shutdown
interface Ethernet105/1/27
  shutdown
interface Ethernet105/1/28
  shutdown
interface Ethernet105/1/29
  shutdown
interface Ethernet105/1/30
  shutdown
interface Ethernet105/1/31
  shutdown
interface Ethernet105/1/32
  shutdown
interface Ethernet106/1/1
  description i=Eth106/1/1 h=ESX01a t=Port-Channel
  channel-group 1201
interface Ethernet106/1/2
  description i=Eth106/1/2 h=ESX02a t=Port-Channel
  channel-group 1202
interface Ethernet106/1/3
  description i=Eth106/1/3 h=ESX03a t=Port-Channel
  channel-group 1203
interface Ethernet106/1/4
  description i=Eth106/1/4 h=ESX04a t=Port-Channel
  channel-group 1204
interface Ethernet106/1/5
  description i=Eth106/1/6 h=ESX05a t=Port-Channel
  channel-group 1205
interface Ethernet106/1/6
  description i=Eth106/1/6 h=ESX06a t=Port-Channel
  channel-group 1206
interface Ethernet106/1/7
  description i=Eth106/1/7 h=ESX07a t=Port-Channel
  channel-group 1207
interface Ethernet106/1/8
  description i=Eth106/1/8 h=ESX08a t=Port-Channel
  channel-group 1208
interface Ethernet106/1/9
  description i=Eth106/1/9 h=ESX09a t=Port-Channel
  channel-group 1209
interface Ethernet106/1/10
  description i=Eth106/1/10 h=ESX10a t=Port-Channel
  channel-group 1210
interface Ethernet106/1/11
  description i=Eth106/1/11 h=ESX11a t=Port-Channel
  channel-group 1211
interface Ethernet106/1/12
  description i=Eth106/1/12 h=ESX12a t=Port-Channel
  channel-group 1212
interface Ethernet106/1/13
  description i=Eth106/1/13 h=ESX13a t=Port-Channel
  channel-group 1213
interface Ethernet106/1/14
  description i=Eth106/1/14 h=ESX14a t=Port-Channel
  channel-group 1214
interface Ethernet106/1/15
  description i=Eth106/1/15 h=ESX15a t=Port-Channel
  channel-group 1215
interface Ethernet106/1/16
  description i=Eth106/1/16 h=ESX16a t=Port-Channel
  channel-group 1216
interface Ethernet106/1/17
  description i=Eth106/1/17 h=ESX1a t=Port-Channel
  channel-group 1217
interface Ethernet106/1/18
  description i=Eth106/1/18 h=ESX2a t=Port-Channel
  channel-group 1218
interface Ethernet106/1/19
  description i=Eth106/1/19 h=ESX3a t=Port-Channel
  channel-group 1219
interface Ethernet106/1/20
  description i=Eth106/1/20 h=ESX4a t=Port-Channel
  channel-group 1220
interface Ethernet106/1/21
  description i=Eth106/1/20 h=ESX5a t=Port-Channel
  channel-group 1221
interface Ethernet106/1/22
  description i=Eth106/1/22 h=ESX6a t=Port-Channel
  channel-group 1222
interface Ethernet106/1/23
  description i=Eth106/1/23 h=ESX7a t=Port-Channel
  channel-group 1223
interface Ethernet106/1/24
  description i=Eth106/1/24 h=ESX8a t=Port-Channel
  channel-group 1224
interface Ethernet106/1/25
  description i=Eth106/1/25 h=ESX9a t=Port-Channel
  channel-group 1225
interface Ethernet106/1/26
  description i=Eth106/1/26 h=ESX10a t=Port-Channel
  channel-group 1226
interface Ethernet106/1/27
  description i=Eth106/1/27 h=ESX11a t=Port-Channel
  channel-group 1227
interface Ethernet106/1/28
  description i=Eth106/1/28 h=ESX12a t=Port-Channel
  channel-group 1228
interface Ethernet106/1/29
  description i=Eth106/1/29 h=ESX13a t=Port-Channel
  channel-group 1229
interface Ethernet106/1/30
  description i=Eth106/1/30 h=ESX14a t=Port-Channel
  channel-group 1230
interface Ethernet106/1/31
  description i=Eth106/1/31 h=ESX15a t=Port-Channel
  channel-group 1231
interface Ethernet106/1/32
  description i=Eth106/1/32 h=ESX16a t=Port-Channel
  channel-group 1232
interface Ethernet106/1/33
  shutdown
interface Ethernet106/1/34
  shutdown
interface Ethernet106/1/35
  shutdown
interface Ethernet106/1/36
  shutdown
interface Ethernet106/1/37
  shutdown
interface Ethernet106/1/38
  shutdown
interface Ethernet106/1/39
  shutdown
interface Ethernet106/1/40
  shutdown
interface Ethernet106/1/41
  shutdown
interface Ethernet106/1/42
  shutdown
interface Ethernet106/1/43
  shutdown
interface Ethernet106/1/44
  shutdown
interface Ethernet106/1/45
  shutdown
interface Ethernet106/1/46
  shutdown
interface Ethernet106/1/47
  shutdown
interface Ethernet106/1/48
  shutdown
interface Ethernet107/1/1
  description i=Eth107/1/1 h=ESX1b t=Port-Channel
  channel-group 1301
interface Ethernet107/1/2
  description i=Eth107/1/2 h=ESX2b t=Port-Channel
  channel-group 1302
interface Ethernet107/1/3
  description i=Eth107/1/3 h=ESX3b t=Port-Channel
  channel-group 1303
interface Ethernet107/1/4
  description i=Eth107/1/4 h=ESX4b t=Port-Channel
  channel-group 1304
interface Ethernet107/1/5
  description i=Eth107/1/5 h=ESX5b t=Port-Channel
  channel-group 1305
interface Ethernet107/1/6
  description i=Eth107/1/6 h=ESX6b t=Port-Channel
  channel-group 1306
interface Ethernet107/1/7
  description i=Eth107/1/7 h=ESX7b t=Port-Channel
  channel-group 1307
interface Ethernet107/1/8
  description i=Eth107/1/8 h=ESX8b t=Port-Channel
  channel-group 1308
interface Ethernet107/1/9
  description i=Eth107/1/9 h=ESX9b t=Port-Channel
  channel-group 1309
interface Ethernet107/1/10
  description i=Eth107/1/10 h=ESX10b t=Port-Channel
  channel-group 1310
interface Ethernet107/1/11
  description i=Eth107/1/11 h=ESX11b t=Port-Channel
  channel-group 1311
interface Ethernet107/1/12
  description i=Eth107/1/12 h=ESX12b t=Port-Channel
  channel-group 1312
interface Ethernet107/1/13
  description i=Eth107/1/13 h=ESX13b t=Port-Channel
  channel-group 1313
interface Ethernet107/1/14
  description i=Eth107/1/14 h=ESX14b t=Port-Channel
  channel-group 1314
interface Ethernet107/1/15
  description i=Eth107/1/15 h=ESX15b t=Port-Channel
  channel-group 1315
interface Ethernet107/1/16
  description i=Eth107/1/16 h=ESX16b t=Port-Channel
  channel-group 1316
interface Ethernet107/1/17
  description i=Eth107/1/17 h=ESX01b t=Port-Channel
  channel-group 1317
interface Ethernet107/1/18
  description i=Eth107/1/18 h=ESX02b t=Port-Channel
  channel-group 1318
interface Ethernet107/1/19
  description i=Eth107/1/19 h=ESX03b t=Port-Channel
  channel-group 1319
interface Ethernet107/1/20
  description i=Eth107/1/20 h=ESX04b t=Port-Channel
  channel-group 1320
interface Ethernet107/1/21
  description i=Eth107/1/21 h=ESX05b t=Port-Channel
  channel-group 1321
interface Ethernet107/1/22
  description i=Eth107/1/22 h=ESX06b t=Port-Channel
  channel-group 1322
interface Ethernet107/1/23
  description i=Eth107/1/23 h=ESX07b t=Port-Channel
  channel-group 1323
interface Ethernet107/1/24
  description i=Eth107/1/24 h=ESX08b t=Port-Channel
  channel-group 1324
interface Ethernet107/1/25
  description i=Eth107/1/25 h=ESX09b t=Port-Channel
  channel-group 1325
interface Ethernet107/1/26
  description i=Eth107/1/26 h=ESX10b t=Port-Channel
  channel-group 1326
interface Ethernet107/1/27
  description i=Eth107/1/27 h=ESX11b t=Port-Channel
  channel-group 1327
interface Ethernet107/1/28
  description i=Eth107/1/28 h=ESX12b t=Port-Channel
  channel-group 1328
interface Ethernet107/1/29
  description i=Eth107/1/29 h=ESX13b t=Port-Channel
  channel-group 1329
interface Ethernet107/1/30
  description i=Eth107/1/30 h=ESX14b t=Port-Channel
  channel-group 1330
interface Ethernet107/1/31
  description i=Eth107/1/31 h=ESX15b t=Port-Channel
  channel-group 1331
interface Ethernet107/1/32
  description i=Eth107/1/32 h=ESX16b t=Port-Channel
  channel-group 1332
interface Ethernet107/1/33
  shutdown
interface Ethernet107/1/34
  shutdown
interface Ethernet107/1/35
  shutdown
interface Ethernet107/1/36
  shutdown
interface Ethernet107/1/37
  shutdown
interface Ethernet107/1/38
  shutdown
interface Ethernet107/1/39
  shutdown
interface Ethernet107/1/40
  shutdown
interface Ethernet107/1/41
  shutdown
interface Ethernet107/1/42
  shutdown
interface Ethernet107/1/43
  shutdown
interface Ethernet107/1/44
  shutdown
interface Ethernet107/1/45
  shutdown
interface Ethernet107/1/46
  shutdown
interface Ethernet107/1/47
  shutdown
interface Ethernet107/1/48
  shutdown
clock timezone CET 1 0
clock summer-time CEST 5 sunday march 02:00 5 sunday october 03:00 60
cli alias name wr copy run start
line console
line vty
  access-class SSHlogin in
boot kickstart bootflash:/n5000-uk9-kickstart.5.0.3.N2.2.bin
boot system bootflash:/n5000-uk9.5.0.3.N2.2.bin
ip radius source-interface mgmt0
logging server 10.10.8.30 6
logging server 10.10.8.13 6
logging monitor 6
logging monitor 6
_______________________________________________________________________________________________
z6-nex# sh run
Communication could not be established with the process
!Time: Thu Nov 17 15:40:15 2011
version 5.0(3)N2(2)
no feature telnet
cfs eth distribute
feature udld
feature lacp
feature vpc
feature lldp
feature fex
ip domain-lookup
    server 10.10.8.53
    use-vrf management
hostname z6-nex
ip access-list SNMP
  30 deny ip any any
  30 deny ip any any
  match qos-group 1
  match qos-group 2
  match qos-group 2
  match qos-group 1
  match qos-group 2
  match qos-group 2
fex 100
  pinning max-links 8
  description "FEX0100"
fex 101
  pinning max-links 8
  description "FEX0101"
fex 102
  pinning max-links 4
  description "FEX0102"
fex 103
  pinning max-links 4
  description "FEX0103"
snmp-server host 10.10.8.14 traps version 2c z6-nex
snmp-server enable traps entity fru
vlan 1
vlan 64
vlan 1950
vlan 1972
vpc domain 99
  role priority 1000
  peer-keepalive destination 10.10.3.131
  vpc 10
  vpc 11
  description i=po99 e1/47 e1/48 s=g6-nex u=po99 t=vPCpeerLink
  vpc peer-link
  description i=po1001 Eth100/1/1 - Eth104/1/1 t=Port-Channel
  vpc 1001
  description i=po1002 Eth100/1/2 - Eth104/1/2 t=Port-Channel
  vpc 1002
  description i=po1003 Eth100/1/3 - Eth104/1/3 t=Port-Channel
  vpc 1003
  description i=po1004 Eth100/1/4 - Eth104/1/4 t=Port-Channel
  vpc 1004
  description i=po1005 Eth100/1/5 - Eth104/1/5 t=Port-Channel
  vpc 1005
  description i=po1006 Eth100/1/6 - Eth104/1/6 t=Port-Channel
  vpc 1006
  description i=po1007 Eth100/1/7 - Eth104/1/7 t=Port-Channel
  vpc 1007
  description i=po1008 Eth100/1/8 - Eth104/1/8 t=Port-Channel
  vpc 1008
[K
  description i=po1009 Eth100/1/9 - Eth104/1/9 t=Port-Channel
  vpc 1009
  description i=po1010 Eth100/1/10 - Eth104/1/10 t=Port-Channel
  vpc 1010
  description i=po1011 Eth100/1/11 - Eth104/1/11 t=Port-Channel
  vpc 1011
  description i=po1012 Eth100/1/12 - Eth104/1/12 t=Port-Channel
  vpc 1012
  description i=po1013 Eth100/1/13 - Eth104/1/13 t=Port-Channel
  vpc 1013
  description i=po1014 Eth100/1/14 - Eth104/1/14 t=Port-Channel
  vpc 1014
  description i=po1015 Eth100/1/15 - Eth104/1/15 t=Port-Channel
  vpc 1015
  description i=po1016 Eth100/1/16 - Eth104/1/16 t=Port-Channel
  vpc 1016
  description i=po1101 Eth101/1/1 - Eth105/1/1 t=Port-Channel
  vpc 1101
  description i=po1102 Eth101/1/2 - Eth105/1/2 t=Port-Channel
  vpc 1102
  description i=po1103 Eth101/1/3 - Eth105/1/3 t=Port-Channel
  vpc 1103
  description i=po1104 Eth101/1/4 - Eth105/1/4 t=Port-Channel
  vpc 1104
  description i=po1105 Eth101/1/5 - Eth105/1/5 t=Port-Channel
  vpc 1105
  description i=po1106 Eth101/1/6 - Eth105/1/6 t=Port-Channel
  vpc 1106
  description i=po1107 Eth101/1/7 - Eth105/1/7 t=Port-Channel
  vpc 1107
  description i=po1108 Eth101/1/8 - Eth105/1/8 t=Port-Channel
  vpc 1108
  description i=po1109 Eth101/1/9 - Eth105/1/9 t=Port-Channel
  vpc 1109
  description i=po1110 Eth101/1/10 - Eth105/1/10 t=Port-Channel
  vpc 1110
  description i=po1111 Eth101/1/11 - Eth105/1/11 t=Port-Channel
  vpc 1111
  description i=po1112 Eth101/1/12 - Eth105/1/12 t=Port-Channel
  vpc 1112
  description i=po1113 Eth101/1/13 - Eth105/1/13 t=Port-Channel
  vpc 1113
  description i=po1114 Eth101/1/14 - Eth105/1/14 t=Port-Channel
  vpc 1114
  description i=po1115 Eth101/1/15 - Eth105/1/15 t=Port-Channel
  vpc 1115
  description i=po1116 Eth101/1/16 - Eth105/1/16 t=Port-Channel
  vpc 1116
  description i=po1201 Eth102/1/1 - Eth106/1/1 t=Port-Channel
  vpc 1201
  description i=po1202 Eth102/1/2 - Eth106/1/2 t=Port-Channel
  vpc 1202
  description i=po1203 Eth102/1/3 - Eth106/1/3 t=Port-Channel
  vpc 1203
  description i=po1204 Eth102/1/4 - Eth106/1/4 t=Port-Channel
  vpc 1204
  description i=po1205 Eth102/1/5 - Eth106/1/5 t=Port-Channel
  vpc 1205
  description i=po1206 Eth102/1/6 - Eth106/1/6 t=Port-Channel
  vpc 1206
  description i=po1207 Eth102/1/7 - Eth106/1/7 t=Port-Channel
  vpc 1207
  description i=po1208 Eth102/1/8 - Eth106/1/8 t=Port-Channel
  vpc 1208
  description i=po1209 Eth102/1/9 - Eth106/1/9 t=Port-Channel
  vpc 1209
  description i=po1210 Eth102/1/10 - Eth106/1/10 t=Port-Channel
  vpc 1210
  description i=po1211 Eth102/1/11 - Eth106/1/11 t=Port-Channel
  vpc 1211
  description i=po1212 Eth102/1/12 - Eth106/1/12 t=Port-Channel
  vpc 1212
  description i=po1213 Eth102/1/13 - Eth106/1/13 t=Port-Channel
  vpc 1213
  description i=po1214 Eth102/1/14 - Eth106/1/14 t=Port-Channel
  vpc 1214
  description i=po1215 Eth102/1/15 - Eth106/1/15 t=Port-Channel
  vpc 1215
  description i=po1216 Eth102/1/16 - Eth106/1/16 t=Port-Channel
  vpc 1216
  description i=po1217 Eth102/1/17 - Eth106/1/17 t=Port-Channel
  vpc 1217
  description i=po1218 Eth102/1/18 - Eth106/1/18 t=Port-Channel
  vpc 1218
  description i=po1219 Eth102/1/19 - Eth106/1/19 t=Port-Channel
  vpc 1219
  description i=po1220 Eth102/1/20 - Eth106/1/20 t=Port-Channel
  vpc 1220
  description i=po1221 Eth102/1/21 - Eth106/1/21 t=Port-Channel
  vpc 1221
  description i=po1222 Eth102/1/22 - Eth106/1/22 t=Port-Channel
  vpc 1222
  description i=po1223 Eth102/1/23 - Eth106/1/23 t=Port-Channel
  vpc 1223
  description i=po1224 Eth102/1/24 - Eth106/1/24 t=Port-Channel
  vpc 1224
  description i=po1225 Eth102/1/25 - Eth106/1/25 t=Port-Channel
  vpc 1225
  description i=po1226 Eth102/1/26 - Eth106/1/26 t=Port-Channel
  vpc 1226
  description i=po1227 Eth102/1/27 - Eth106/1/27 t=Port-Channel
  vpc 1227
  description i=po1228 Eth102/1/28 - Eth106/1/28 t=Port-Channel
  vpc 1228
  description i=po1229 Eth102/1/29 - Eth106/1/29 t=Port-Channel
  vpc 1229
  description i=po1230 Eth102/1/30 - Eth106/1/30 t=Port-Channel
  vpc 1230
  description i=po1231 Eth102/1/31 - Eth106/1/31 t=Port-Channel
  vpc 1231
  description i=po1232 Eth102/1/32 - Eth106/1/32 t=Port-Channel
  vpc 1232
  description i=po1301 Eth103/1/1 - Eth107/1/1 t=Port-Channel
  vpc 1301
  description i=po1302 Eth103/1/2 - Eth107/1/2 t=Port-Channel
  vpc 1302
  description i=po1303 Eth103/1/3 - Eth107/1/3 t=Port-Channel
  vpc 1303
  description i=po1304 Eth103/1/4 - Eth107/1/4 t=Port-Channel
  vpc 1304
  description i=po1305 Eth103/1/5 - Eth107/1/5 t=Port-Channel
  vpc 1305
  description i=po1306 Eth103/1/6 - Eth107/1/6 t=Port-Channel
  vpc 1306
  description i=po1307 Eth103/1/7 - Eth107/1/7 t=Port-Channel
  vpc 1307
  description i=po1308 Eth103/1/8 - Eth107/1/8 t=Port-Channel
  vpc 1308
  description i=po1309 Eth103/1/9 - Eth107/1/9 t=Port-Channel
  vpc 1309
  description i=po1310 Eth103/1/10 - Eth107/1/10 t=Port-Channel
  vpc 1310
  description i=po1311 Eth103/1/11 - Eth107/1/1 t=Port-Channel
  vpc 1311
  description i=po1312 Eth103/1/12 - Eth107/1/12 t=Port-Channel
  vpc 1312
  description i=po1313 Eth103/1/13 - Eth107/1/13 t=Port-Channel
  vpc 1313
  description i=po1314 Eth103/1/14 - Eth107/1/14 t=Port-Channel
  vpc 1314
  description i=po1315 Eth103/1/15 - Eth107/1/15 t=Port-Channel
  vpc 1315
  description i=po1316 Eth103/1/16 - Eth107/1/16 t=Port-Channel
  vpc 1316
  description i=po1317 Eth103/1/17 - Eth107/1/17 t=Port-Channel
  vpc 1317
  description i=po1318 Eth103/1/18 - Eth107/1/18 t=Port-Channel
  vpc 1318
  description i=po1319 Eth103/1/19 - Eth107/1/19 t=Port-Channel
  vpc 1319
  description i=po1320 Eth103/1/20 - Eth107/1/20 t=Port-Channel
  vpc 1320
  description i=po1321 Eth103/1/21 - Eth107/1/21 t=Port-Channel
  vpc 1321
  description i=po1322 Eth103/1/22 - Eth107/1/22 t=Port-Channel
  vpc 1322
  description i=po1323 Eth103/1/23 - Eth107/1/23 t=Port-Channel
  vpc 1323
  description i=po1324 Eth103/1/24 - Eth107/1/24 t=Port-Channel
  vpc 1324
  description i=po1325 Eth103/1/25 - Eth107/1/25 t=Port-Channel
  vpc 1325
  description i=po1326 Eth103/1/26 - Eth107/1/26 t=Port-Channel
  vpc 1326
  description i=po1327 Eth103/1/27 - Eth107/1/27 t=Port-Channel
  vpc 1327
  description i=po1328 Eth103/1/28 - Eth107/1/28 t=Port-Channel
  vpc 1328
[K
  description i=po1329 Eth103/1/29 - Eth107/1/29 t=Port-Channel
  vpc 1329
  description i=po1330 Eth103/1/30 - Eth107/1/30 t=Port-Channel
  vpc 1330
  description i=po1331 Eth103/1/31 - Eth107/1/31 t=Port-Channel
  vpc 1331
  description i=po1332 Eth103/1/32 - Eth107/1/32 t=Port-Channel
  vpc 1332
  description i=e1/01 s=FEX100-10GB t=FEX-Uplink
  fex associate 100
  description i=e1/02 s=FEX100-10GB t=FEX-Uplink
  fex associate 100
  description i=e1/03 s=FEX100-10GB t=FEX-Uplink
  fex associate 100
  description i=e1/04 s=FEX100-10GB t=FEX-Uplink
  fex associate 100
  description i=e1/05 s=FEX100-10GB t=FEX-Uplink
  fex associate 100
  description i=e1/06 s=FEX100-10GB t=FEX-Uplink
  fex associate 100
  description i=e1/07 s=FEX100-10GB t=FEX-Uplink
  fex associate 100
  description i=e1/08 s=FEX100-10GB t=FEX-Uplink
  fex associate 100
  description i=e1/09 s=FEX101-10GB t=FEX-Uplink
  fex associate 101
  description i=e1/10 s=FEX101-10GB t=FEX-Uplink
  fex associate 101
  description i=e1/11 s=FEX101-10GB t=FEX-Uplink
  fex associate 101
  description i=e1/12 s=FEX101-10GB t=FEX-Uplink
  fex associate 101
  description i=e1/13 s=FEX101-10GB t=FEX-Uplink
  fex associate 101
  description i=e1/14 s=FEX101-10GB t=FEX-Uplink
  fex associate 101
  description i=e1/15 s=FEX101-10GB t=FEX-Uplink
  fex associate 101
  description i=e1/16 s=FEX101-10GB t=FEX-Uplink
  fex associate 101
  description i=e1/17 s=FEX102-1GB t=FEX-Uplink
  fex associate 102
  description i=e1/18 s=FEX102-1GB t=FEX-Uplink
  fex associate 102
  description i=e1/19 s=FEX102-1GB t=FEX-Uplink
  fex associate 102
  description i=e1/20 s=FEX102-1GB t=FEX-Uplink
  fex associate 102
  description i=e1/21 s=FEX103-1GB t=FEX-Uplink
  fex associate 103
  description i=e1/22 s=FEX103-1GB t=FEX-Uplink
  fex associate 103
  description i=e1/23 s=FEX103-1GB t=FEX-Uplink
  fex associate 103
  description i=e1/24 s=FEX103-1GB t=FEX-Uplink
  fex associate 103
[K
  description i=e1/41 s=s6-4-smn1 gi2/0/52 v=1950,1972
  speed 1000
  description i=Eth1/43 s=g6-c65 gi2/23 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth1/44 s=g6-c65 gi2/24 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth1/45 s=z6-c65 gi2/19 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth1/46 s=z6-c65 gi2/20 t=trunk v=64
  speed 1000
  udld aggressive
  description i=e1/47 s=g6-nex u=e1/47 t=vPCpeerLink-Domain99
  udld aggressive
  channel-group 99
  description i=e1/48 s=g6-nex u=e1/48 t=vPCpeerLink-Domain99
  udld aggressive
  channel-group 99
[K
  description i=Eth2/13 s=g6-c65 gi2/21 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth2/14 s=g6-c65 gi2/22 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth2/15 s=z6-c65 gi2/17 t=trunk v=64
  speed 1000
  udld aggressive
  description i=Eth2/16 s=z6-c65 gi2/18 t=trunk v=64
  speed 1000
  udld aggressive
interface mgmt0
  ip address 10.10.3.130/24
interface Ethernet100/1/1
  description i=Eth100/1/1 h=ESX01a t=Port-Channel
  channel-group 1001
interface Ethernet100/1/2
  description i=Eth100/1/2 h=ESX02a t=Port-Channel
  channel-group 1002
interface Ethernet100/1/3
  description i=Eth100/1/3 h=ESX03a t=Port-Channel
  channel-group 1003
interface Ethernet100/1/4
  description i=Eth100/1/4 h=ESX04a t=Port-Channel
  channel-group 1004
interface Ethernet100/1/5
  description i=Eth100/1/5 h=ESX05a t=Port-Channel
  channel-group 1005
interface Ethernet100/1/6
  description i=Eth100/1/6 h=ESX06a t=Port-Channel
  channel-group 1006
interface Ethernet100/1/7
  description i=Eth100/1/7 h=ESX06a t=Port-Channel
  channel-group 1007
interface Ethernet100/1/8
  description i=Eth100/1/8 h=ESX09a t=Port-Channel
  channel-group 1008
interface Ethernet100/1/9
  description i=Eth100/1/9 h=ESX10a t=Port-Channel
  channel-group 1009
interface Ethernet100/1/10
  description i=Eth100/1/10 h=ESX11a t=Port-Channel
  channel-group 1010
interface Ethernet100/1/11
  description i=Eth100/1/11 h=ESX12a t=Port-Channel
  channel-group 1011
interface Ethernet100/1/12
  description i=Eth100/1/12 h=ESX13a t=Port-Channel
  channel-group 1012
interface Ethernet100/1/13
  description i=Eth100/1/13 h=ESX14a t=Port-Channel
  channel-group 1013
interface Ethernet100/1/14
  description i=Eth100/1/14 h=ESX15a t=Port-Channel
  channel-group 1014
interface Ethernet100/1/15
  description i=Eth100/1/15 h=ESX0 t=Port-Channel
  channel-group 1015
interface Ethernet100/1/16
  description i=Eth100/1/16 h=ESX16a t=Port-Channel
  channel-group 1016
interface Ethernet100/1/17
interface Ethernet100/1/18
interface Ethernet100/1/19
interface Ethernet100/1/20
interface Ethernet100/1/21
interface Ethernet100/1/22
interface Ethernet100/1/23
interface Ethernet100/1/24
interface Ethernet100/1/25
interface Ethernet100/1/26
interface Ethernet100/1/27
interface Ethernet100/1/28
interface Ethernet100/1/29
interface Ethernet100/1/30
interface Ethernet100/1/31
interface Ethernet100/1/32
interface Ethernet101/1/1
  description i=Eth101/1/1 h=ESX01b t=Port-Channel
  channel-group 1101
interface Ethernet101/1/2
  description i=Eth101/1/2 h=ESX02b t=Port-Channel
  channel-group 1102
interface Ethernet101/1/3
  description i=Eth101/1/3 h=ESX03b t=Port-Channel
  channel-group 1103
interface Ethernet101/1/4
  description i=Eth101/1/4 h=ESX04b t=Port-Channel
  channel-group 1104
interface Ethernet101/1/5
  description i=Eth101/1/5 h=ESX05b t=Port-Channel
  channel-group 1105
interface Ethernet101/1/6
  description i=Eth101/1/6 h=ESX06b t=Port-Channel
  channel-group 1106
interface Ethernet101/1/7
  description i=Eth101/1/7 h=ESX07b t=Port-Channel
  channel-group 1107
interface Ethernet101/1/8
  description i=Eth101/1/8 h=ESX08b t=Port-Channel
  channel-group 1108
interface Ethernet101/1/9
  description i=Eth101/1/9 h=ESX09b t=Port-Channel
  channel-group 1109
interface Ethernet101/1/10
  description i=Eth101/1/10 h=ESX10b t=Port-Channel
  channel-group 1110
interface Ethernet101/1/11
  description i=Eth101/1/11 h=ESX11b t=Port-Channel
  channel-group 1111
interface Ethernet101/1/12
  description i=Eth101/1/12 h=ESX12b t=Port-Channel
  channel-group 1112
interface Ethernet101/1/13
  description i=Eth101/1/13 h=ESX13b t=Port-Channel
  channel-group 1113
interface Ethernet101/1/14
  description i=Eth101/1/14 h=ESX14b t=Port-Channel
  channel-group 1114
interface Ethernet101/1/15
  description i=Eth101/1/15 h=ESX15b t=Port-Channel
  channel-group 1115
interface Ethernet101/1/16
  description i=Eth101/1/16 h=ESX16b t=Port-Channel
  channel-group 1116
interface Ethernet101/1/17
  shutdown
interface Ethernet101/1/18
  shutdown
interface Ethernet101/1/19
  shutdown
interface Ethernet101/1/20
  shutdown
interface Ethernet101/1/21
  shutdown
interface Ethernet101/1/22
  shutdown
interface Ethernet101/1/23
  shutdown
interface Ethernet101/1/24
  shutdown
interface Ethernet101/1/25
  shutdown
interface Ethernet101/1/26
  shutdown
interface Ethernet101/1/27
  shutdown
interface Ethernet101/1/28
  shutdown
interface Ethernet101/1/29
  shutdown
interface Ethernet101/1/30
  shutdown
interface Ethernet101/1/31
  shutdown
interface Ethernet101/1/32
  shutdown
interface Ethernet102/1/1
  description i=Eth102/1/1 h=ESX01a t=Port-Channel
  channel-group 1201
interface Ethernet102/1/2
  description i=Eth102/1/2 h=ESX02a t=Port-Channel
  channel-group 1202
interface Ethernet102/1/3
  description i=Eth102/1/3 h=ESX03a t=Port-Channel
  channel-group 1203
interface Ethernet102/1/4
  description i=Eth102/1/4 h=ESX04a t=Port-Channel
  channel-group 1204
interface Ethernet102/1/5
  description i=Eth102/1/6 h=ESX05a t=Port-Channel
  channel-group 1205
interface Ethernet102/1/6
  description i=Eth102/1/6 h=ESX06a t=Port-Channel
  channel-group 1206
interface Ethernet102/1/7
  description i=Eth102/1/7 h=ESX07a t=Port-Channel
  channel-group 1207
interface Ethernet102/1/8
  description i=Eth102/1/8 h=ESX08a t=Port-Channel
  channel-group 1208
interface Ethernet102/1/9
  description i=Eth102/1/9 h=ESX09a t=Port-Channel
  channel-group 1209
interface Ethernet102/1/10
  description i=Eth102/1/10 h=ESX10a t=Port-Channel
  channel-group 1210
interface Ethernet102/1/11
  description i=Eth102/1/11 h=ESX11a t=Port-Channel
  channel-group 1211
interface Ethernet102/1/12
  description i=Eth102/1/12 h=ESX12a t=Port-Channel
  channel-group 1212
interface Ethernet102/1/13
  description i=Eth102/1/13 h=ESX13a t=Port-Channel
  channel-group 1213
interface Ethernet102/1/14
  description i=Eth102/1/14 h=ESX14a t=Port-Channel
  channel-group 1214
interface Ethernet102/1/15
  description i=Eth102/1/15 h=ESX15a t=Port-Channel
  channel-group 1215
interface Ethernet102/1/16
  description i=Eth102/1/16 h=ESX16a t=Port-Channel
  channel-group 1216
interface Ethernet102/1/17
  description i=Eth102/1/17 h=ESX1a t=Port-Channel
  channel-group 1217
interface Ethernet102/1/18
  description i=Eth102/1/18 h=ESX2a t=Port-Channel
  channel-group 1218
interface Ethernet102/1/19
  description i=Eth102/1/19 h=ESX3a t=Port-Channel
  channel-group 1219
interface Ethernet102/1/20
  description i=Eth102/1/20 h=ESX4a t=Port-Channel
  channel-group 1220
interface Ethernet102/1/21
  description i=Eth102/1/20 h=ESX5a t=Port-Channel
  channel-group 1221
interface Ethernet102/1/22
  description i=Eth102/1/22 h=ESX6a t=Port-Channel
  channel-group 1222
interface Ethernet102/1/23
  description i=Eth102/1/23 h=ESX7a t=Port-Channel
  channel-group 1223
interface Ethernet102/1/24
  description i=Eth102/1/24 h=ESX8a t=Port-Channel
  channel-group 1224
interface Ethernet102/1/25
  description i=Eth102/1/25 h=ESX9a t=Port-Channel
  channel-group 1225
interface Ethernet102/1/26
  description i=Eth102/1/26 h=ESX10a t=Port-Channel
  channel-group 1226
interface Ethernet102/1/27
  description i=Eth102/1/27 h=ESX11a t=Port-Channel
  channel-group 1227
interface Ethernet102/1/28
  description i=Eth102/1/28 h=ESX12a t=Port-Channel
  channel-group 1228
interface Ethernet102/1/29
  description i=Eth102/1/29 h=ESX13a t=Port-Channel
  channel-group 1229
interface Ethernet102/1/30
  description i=Eth102/1/30 h=ESX14a t=Port-Channel
  channel-group 1230
interface Ethernet102/1/31
  description i=Eth102/1/31 h=ESX15a t=Port-Channel
  channel-group 1231
interface Ethernet102/1/32
  description i=Eth102/1/32 h=ESX16a t=Port-Channel
  channel-group 1232
interface Ethernet102/1/33
  shutdown
interface Ethernet102/1/34
  shutdown
interface Ethernet102/1/35
  shutdown
interface Ethernet102/1/36
  shutdown
interface Ethernet102/1/37
  shutdown
interface Ethernet102/1/38
  shutdown
interface Ethernet102/1/39
  shutdown
interface Ethernet102/1/40
  shutdown
interface Ethernet102/1/41
  shutdown
interface Ethernet102/1/42
  shutdown
interface Ethernet102/1/43
  shutdown
interface Ethernet102/1/44
  shutdown
interface Ethernet102/1/45
  shutdown
interface Ethernet102/1/46
  shutdown
interface Ethernet102/1/47
  shutdown
interface Ethernet102/1/48
  shutdown
interface Ethernet103/1/1
  description i=Eth103/1/1 h=ESX1b t=Port-Channel
  channel-group 1301
interface Ethernet103/1/2
  description i=Eth103/1/2 h=ESX2b t=Port-Channel
  channel-group 1302
interface Ethernet103/1/3
  description i=Eth103/1/3 h=ESX3b t=Port-Channel
  channel-group 1303
interface Ethernet103/1/4
  description i=Eth103/1/4 h=ESX4b t=Port-Channel
  channel-group 1304
interface Ethernet103/1/5
  description i=Eth103/1/5 h=ESX5b t=Port-Channel
  channel-group 1305
interface Ethernet103/1/6
  description i=Eth103/1/6 h=ESX6b t=Port-Channel
  channel-group 1306
interface Ethernet103/1/7
  description i=Eth103/1/7 h=ESX7b t=Port-Channel
  channel-group 1307
interface Ethernet103/1/8
  description i=Eth103/1/8 h=ESX8b t=Port-Channel
  channel-group 1308
interface Ethernet103/1/9
  description i=Eth103/1/9 h=ESX9b t=Port-Channel
  channel-group 1309
interface Ethernet103/1/10
  description i=Eth103/1/10 h=ESX10b t=Port-Channel
  channel-group 1310
interface Ethernet103/1/11
  description i=Eth103/1/11 h=ESX11b t=Port-Channel
  channel-group 1311
interface Ethernet103/1/12
  description i=Eth103/1/12 h=ESX12b t=Port-Channel
  channel-group 1312
interface Ethernet103/1/13
  description i=Eth103/1/13 h=ESX13b t=Port-Channel
  channel-group 1313
interface Ethernet103/1/14
  description i=Eth103/1/14 h=ESX14b t=Port-Channel
  channel-group 1314
interface Ethernet103/1/15
  description i=Eth103/1/15 h=ESX15b t=Port-Channel
  channel-group 1315
interface Ethernet103/1/16
  description i=Eth103/1/16 h=ESX16b t=Port-Channel
  channel-group 1316
interface Ethernet103/1/17
  description i=Eth103/1/17 h=ESX01b t=Port-Channel
  channel-group 1317
interface Ethernet103/1/18
  description i=Eth103/1/18 h=ESX02b t=Port-Channel
  channel-group 1318
interface Ethernet103/1/19
  description i=Eth103/1/19 h=ESX03b t=Port-Channel
  channel-group 1319
interface Ethernet103/1/20
  description i=Eth103/1/20 h=ESX04b t=Port-Channel
  channel-group 1320
interface Ethernet103/1/21
  description i=Eth103/1/21 h=ESX05b t=Port-Channel
  channel-group 1321
interface Ethernet103/1/22
  description i=Eth103/1/22 h=ESX06b t=Port-Channel
  channel-group 1322
interface Ethernet103/1/23
  description i=Eth103/1/23 h=ESX07b t=Port-Channel
  channel-group 1323
interface Ethernet103/1/24
  description i=Eth103/1/24 h=ESX08b t=Port-Channel
  channel-group 1324
interface Ethernet103/1/25
  description i=Eth103/1/25 h=ESX09b t=Port-Channel
  channel-group 1325
interface Ethernet103/1/26
  description i=Eth103/1/26 h=ESX10b t=Port-Channel
  channel-group 1326
interface Ethernet103/1/27
  description i=Eth103/1/27 h=ESX11b t=Port-Channel
  channel-group 1327
interface Ethernet103/1/28
  description i=Eth103/1/28 h=ESX12b t=Port-Channel
  channel-group 1328
interface Ethernet103/1/29
  description i=Eth103/1/29 h=ESX13b t=Port-Channel
  channel-group 1329
interface Ethernet103/1/30
  description i=Eth103/1/30 h=ESX14b t=Port-Channel
  channel-group 1330
interface Ethernet103/1/31
  description i=Eth103/1/31 h=ESX15b t=Port-Channel
  channel-group 1331
interface Ethernet103/1/32
  description i=Eth103/1/32 h=ESX16b t=Port-Channel
  channel-group 1332
interface Ethernet103/1/33
  shutdown
interface Ethernet103/1/34
  shutdown
interface Ethernet103/1/35
  shutdown
interface Ethernet103/1/36
  shutdown
interface Ethernet103/1/37
  shutdown
interface Ethernet103/1/38
  shutdown
interface Ethernet103/1/39
  shutdown
interface Ethernet103/1/40
  shutdown
interface Ethernet103/1/41
  shutdown
interface Ethernet103/1/42
  shutdown
interface Ethernet103/1/43
  shutdown
interface Ethernet103/1/44
  shutdown
interface Ethernet103/1/45
  shutdown
interface Ethernet103/1/46
  shutdown
interface Ethernet103/1/47
  shutdown
interface Ethernet103/1/48
line console
line vty
logging monitor 6
logging monitor 6
Jerry Ye
If I understand you question, your C6K is not running VSS mode. Is this a correct statement?
If yes, then your PO10 should not goes to both C6K. It should looks like
HTH,
jerry
Recognize Your Peers
