N7K-F248XP-25E not accepted
g8104
Hi all,
I´ve got a problem with a new line-card I´d like to install in our Nexus 7010.
Informations around the N7k:
Installed SW (system/kickstart) NXOS 6.1(1).
3x 6kw power.
Line-Card should be installed in Slot 8. There´s already a F-card (N7K-F248XP-25 -> without E in the end) installed in slot 1. This one is absolutely fine. The new line-card is only recognized when I do a "show environment power". Then I can see the model and status is "Powered-Dn".
When I do a "show module" it says "Unknown module" and Status is "powered-down".
I did a "no poweroff moduel 8"...logg says "Unknown card. Could not get software-id-card.
Do you have any ideas, what is wrong or what I can do to get the card up and running?
Thanks!
sean_evershed
Level 7
Level 7
Check this link
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/release/notes/61_nx-os_release_note.html
You need to upgrade your code to 6.1(2).
Don't forget to rate all helpful posts.
sean_evershed
Level 7
Level 7
Check this link
Thanks for that information...will update the SW.
