01-28-2016 01:17 PM - edited 03-01-2019 08:10 AM
Can you still order the N7K-M132XP-12L line card? What is the equivalent in the M2 line cards?
01-28-2016 04:05 PM
According to this document it has gone end of sale (October 30, 2016).
Alas it does not give the M2 replacement part number. I suspect it may be more complicated depending on what other hardware is in the 7k.
01-28-2016 04:08 PM
This is a close fit, but only 24 port (N7K-M224XP-23L).
02-02-2016 05:38 PM
Thanks Phil,
That's what i thought. When i went to www.cisco.com/go/nexus and & started looking for that particular line-card; it wouldn't allow me to go any further. It makes sense that its end of sale but just wanted to make sure.
Once again, thanks for your assistance.
02-02-2016 06:13 PM
You're welcome. If you think the answer has helpful it would be great if you could rate it and mark it as correct. :-)
02-02-2016 07:24 PM
There is no equivalent 32 port card. M224 could be a possible choice or you can look into F3 modules as well depending on the required port density and the features you plan to run on this card.
-Raj
