Highlighted
Enthusiast
N7K policy-map output not displayed
Hello all,
When attempting to view a policy on a nexus 7k interface I cannot see the offered rates as you would normally see. Any ideas?
Here is how mine shows up:
7k01# sh policy-map interface e1/1
Global statistics status :   enabled
Ethernet1/1
  Service-policy (queuing) input:   default-in-policy
    SNMP Policy Index:  301989921
    Class-map (queuing):   in-q1 (match-any)
      queue-limit percent 50
      bandwidth percent 80
      queue dropped pkts : 0
    Class-map (queuing):   in-q-default (match-any)
      bandwidth percent 20
  Service-policy (queuing) output:   Nexus-QoS-10G
    SNMP Policy Index:  301992049
    Class-map (queuing):   1p7q4t-out-pq1 (match-any)
      priority level 1
      queue-limit percent 20
    Class-map (queuing):   1p7q4t-out-q2 (match-any)
      random-detect cos-based
      random-detect cos 7 minimum-threshold percent 80 maximum-threshold percent 100
      bandwidth remaining percent 5
    Class-map (queuing):   1p7q4t-out-q3 (match-any)
      random-detect cos 6 minimum-threshold percent 80 maximum-threshold percent 100
    Class-map (queuing):   1p7q4t-out-q4 (match-any)
      random-detect cos 4 minimum-threshold percent 80 maximum-threshold percent 100
      bandwidth remaining percent 15
From the cisco white paper:
Configuration Examples For Monitoring QoS Statistics
The following example shows how to display the QoS statistics:
switch(config)# show policy-map interface ethernet 8/1
Global statistics status: enabled
Ethernet8/1
Service-policy (qos) input: pmap
policy statistics status: enabled
Class-map (qos): map (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: cos 0
police cir 10 mbps bc 200 ms
conformed 0 bytes, 0 bps action: transmit
violated 0 bytes, 0 bps action: drop
Class-map (qos): map1 (match-all)
0 packets, 0 bytes
CCIE RS 34827
0 REPLIES 0
