11-24-2012 12:57 AM - edited 03-01-2019 07:12 AM
While I bring Up Secondary Nexus 1010 I am getting this error on primary
Error in getting supervisor and internal state of other supervisor.
sh redundancy status
Redundancy role
administrative: primary
operational: primary
Redundancy mode
administrative: HA
operational: None
This supervisor (sup-1)
Redundancy state: Active
Supervisor state: Active
Internal state: Active with warm standby
Other supervisor (sup-2)
Redundancy state: Standby
On the redundant (standy ) unit I am getting this message
%SYSLOG-2-SYSTEM_MSG: Did not receive supstate notification in 180 seconds. Still waiting
What could be possible reason ? can this be a firmware mismatch ? Both are having same configuration for management control and packet vlan. Both are on same L2 network. If I disconnect the standby unit management cable, it will boot. But if management cable is connected, it will be stuck in the above phase.
regards
Prasad K
Solved! Go to Solution.
11-26-2012 06:07 AM
Prasad,
This means that there is some sort of a communication issue between the two Nexus 1010 switches in the control VLAN. You should probably check the upstream configuration on the ports that connect to the 1010 links carrying the control traffic and also the links involved in the control path.
Shankar
11-26-2012 06:07 AM
Prasad,
Shankar
12-05-2012 06:32 AM
You are right, The control vlan was broken in the path. But Now VSM (inside this 1010) is giving same error. It is set in L3 mode. The control vlan is 1. Does the N1010 tags control vlan 1 also. My upstream switch uses vlan 1 as native. it looks like there is some issue for HA using vlan 1.
If you some comment please share,
12-05-2012 10:13 AM
When N1k is in L3 mode, the control & packet vlans should be blank. You may need to 'no control vlan x'.
N1010 does not accept native vlans in the default configuration. Native vlan can be assigned in SP1(4)+
conf t
int
native vlan
