Hi All,
So very new to Cisco so please be gentle!
We have inherited a N3K-C3548P-10G switch with a dozen or so SFP-10G-SR sfp modules.
I have performed a write erase on the box and configured as fresh. I am trying to get a link between this 3548 and a small business SG500-52P. We are using a pair of the modules mentioned above but cannot get a link up.
If I put a module into an old netgear I have then the link between the SG500 and the netgear comes up (using an OM4 LC-LC cable) so from that I am guessing that the modules and cabling are ok?
In cli, it is showing Link Not Connected
Core(config)# sh int eth1/1
Ethernet1/1 is down (Link not connected)
Dedicated Interface
Hardware: 100/1000/10000/40000 Ethernet, address: f44e.05b2.e5c8 (bia f44e.05b
2.e5c8)
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is access
Full-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped never
0 interface resets
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
Core(config)# sh int eth1/1 transceiver details
Ethernet1/1
transceiver is present
type is 10Gbase-SR
name is CISCO-JDSU
part number is PLRXPL-SC-S43-CS
revision is 1
serial number is JUR18460QAA
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM2 fiber is 82 m
Link length supported for 62.5/125um fiber is 26 m
Link length supported for 50/125um OM3 fiber is 300 m
cisco id is --
cisco extended id number is 4
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 31.39 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.24 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 5.97 mA 10.00 mA 2.59 mA 8.50 mA 3.00 mA
Tx Power -2.21 dBm 1.69 dBm -11.30 dBm -1.30 dBm -7.30 dBm
Rx Power -3.20 dBm 1.99 dBm -13.97 dBm -1.00 dBm -9.91 dBm
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
Should I be able to get these two boxes talking together with these modules?
Firmware version on the 3548 is 6.0(2)A3(2) and I have the latest recommended version downloaded and ready to apply if I can get connected.
Thanks in advance and apologies if I have posted in the wrong section.
