05-08-2016 04:54 AM - edited 03-01-2019 08:15 AM
Hello
I have the following config, the issue is that
Any ideas?
05-09-2016 06:35 AM
here is my setup on 5ks that's currently working when tacacs is reachable or not it reverts to local passwords may help , I use the vrf though as my mgmt. interface you cant remove it
aaa authentication login default group xxxxx
aaa authentication login console group xxxxx
aaa authorization commands default group xxxxx local
aaa accounting default group xxxxx
tacacs-server directed-request
tacacs-server host 172.x.x.x key 7 "p%DW%h9g76=3!Z+G4!SS"
aaa group server tacacs+ xtacacs
server 172.x.x.x
server 172.x.x.x
use-vrf management
source-interface mgmt0
vrf context management
ip domain-name xxxx
ip route 0.0.0.0/0 172.x.x.x
interface mgmt0
vrf member management
ip address 172.x.x.x/22
05-09-2016 07:29 AM
Hello Mark
I get this error
Error: AAA authorization failed AAA_AUTHOR_STATUS_METHOD=16(0x10)
when I add this part
aaa accounting default group TacServers local
aaa authentication login error-enable
aaa authentication login conssole local
thanks!
05-09-2016 07:42 AM
Whats the config under the mgmt0 interface and is it currently up/up
05-09-2016 02:00 PM
Hello
interface mgmt0
ip address 192.168.1.244/22
Thanks.
