Nexus 5548 with FEX sync peer not rechable;ping ok;CFS peer not showing
Sonugnair_2
We have two Nexus 5548 switches along with a coupe of dual homed FEXes. All vlan, portchannel, interface configurations were done in 'conf sync' mode.
We continued like this and faced no problems. However recently i found out that after a change, i tried to verify and commit, however there is an error saying that the peer is not reachable. But i am able to ping both the Nexus switches from each others console via the appropiate vrfs. I noticed that on switch 1 i am able to see the cfs peers, but on switch 2 on giving the command following is the output:-
5548_02# show cfs peers
CFS Discovery is in Progress ..Please wait
Could not get response. The network topology may be under going change.
Please try after about 30 seconds
5548_02#
{{ Above output takes some time to display}}
I am not able to find much information about this. I disabled CFSoIP and re enabled it. Still same result. I am actually stuck here. The other things to do would be delete the switch profile and add back again or may be reload the switch.
The NX OS is:-
BIOS:      version 3.6.0
loader:    version N/A
kickstart: version 5.2(1)N1(2a)
system:    version 5.2(1)N1(2a)
power-seq: Module 1: version v1.0
Module 3: version v2.0
On switch 1 peers are showing up as normal:-
5548_01# sh cfs peer
Physical Fabric
Switch WWN              IP Address
20:00:54:7f:ee:b7:c2:80 172.16.1.53                           [Local]
                         5548_01
20:00:54:7f:ee:b6:99:c0 172.16.1.51
20:00:54:7f:ee:b6:9c:00 172.16.1.52
20:00:54:7f:ee:b6:3f:80 172.16.1.54
Total number of entries = 4
Any feed back would be appreciated
kthned
Level 3
Level 3
Hi Sonu,
I see the similar problem on my nexus5ks. show cfs peer does not display the peer information. I have been waiting for hours now.
sw01# sh cfs peer
Did you find the fix7workaround of this problem ?
Umair
