Nexus 5548 with Fex vpc and Host server vpc
   Can we have the below setup with VPC on Fex as well as Host Server ?5548-fex.jpg
6 REPLIES 6
mipetrin
Hi Diana,
Yes that can be achieved assuming you are on 5.1(3)N1(1) or later.
You configure this as part of Enhanced vPC. Have a look at the following documentation.
www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/mkt_ops_guides/513_n1_1/n5k_enhanced_vpc.pdf
Michael
Hi Michael,
Thanks for the info.
I have 5.1.3.N1.1a version. I suppose that should support Enhanced vpc.
Thx.
Diana
Yes it does.
When looking at that picture above, how does the upgrade sequence look like ?
The N5Ks are ISSU-enabled but the FEXes are not.
Is there actual downtime for the host server at the bottom ?
Thanks Lucien and Michael.
jkilleda
Participant
Participant
Hello Diana,
Yes , VPC works on any device that supports port channel
