Dear all,
Is there a command similar to IOS "ip forward protocol udp XXXX" on Nexus5548UP to enable udp protocol to be forwarded?
BR
Omar
HI Omar
i dont think the ip forward-protocol config is supported yet but you can try an alternate configuration as below and see if that helps:
access-list 50 permit udp x.x.x.0 0.0.0.255 any permit udp y.y.y.0 0.0.0.255 any interface Vlan10 ip address 172.16.10.X 255.255.255.0 ip directed-broadcast 50
Hope this helps
Hiya, Omar. Did this configlet work for your scenario? I have a similar configuration I am migrating from a Cat 6500 to a N7K. Thanks!
Hi Brian,
at the end customer upgraded the application and we did not need anymore this feature.
BR
Omar
Hi:
I tested this on my platform without success:
interface Vlan779
no shutdown
ip access-group install_vlan_client_in in
no ip redirects
ip address 172.17.8.253/24
ip directed-broadcast UEFI
ip dhcp relay address 172.17.194.1
ip dhcp relay address 172.17.194.20
ip access-list UEFI
10 permit udp any any eq 4011
ip access-lists install_vlan_client_in
500 permit udp 172.17.8.0/24 172.17.194.20/32 eq 4011
I googled without any success, lot of people with this problem but no solution.
Lot of thanks for the help.
Borja
