10-02-2015 10:29 AM - edited 03-01-2019 08:02 AM
I'm trying to upgrade Nexus 5596UP to version 7
I used the command
install all kickstart bootflash:n5000-uk9-kickstart.7.1.1.N1.1.bin system bootflash:n5000-uk9.7.0.1.N1.1.bin
verifying image bootflash:n5000-uk9-kickstart.7.1.1.N1.1.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.7.0.1.N1.1.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n5000-uk9.7.0.1.N1.1.bin.
Extracting "kickstart" version from image bootflash:n5000-uk9-kickstart.7.1.1.N1.1.bin .
Extracting "bios" version from image bootflash:/n5000-uk9.7.0.1.N1.1.bin.
Extracting "fexth" version from image bootflash:/n5000-uk9.7.0.1.N1.1.bin.
Recommended action::
"Module 1 2 3 might not be supported in the new image,
it should be powered off before proceeding with install".
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module bootable Impact Install-type Reason
1 no n/a n/a Incompatible image
2 no n/a n/a Incompatible image
3 no n/a n/a Incompatible image
101 yes disruptive reset Forced by the user
102 yes disruptive reset Forced by the user
103 yes disruptive reset Forced by the user
Images will be upgraded according to following table:
Module Image Running-Version New-Version Upg-Required
1 system 6.0(2)N2(7) 7.0(1)N1(1) no
1 kickstart 6.0(2)N2(7) 7.1(1)N1(1) no
1 bios v3.6.0(05/09/2012) v3.6.0(05/09/2012) no
1 power-seq v7.0 v7.0 no
1 SFP-uC v1.1.0.0 v1.0.0.0 no
2 power-seq v1.0 v1.0 no
3 power-seq v1.0 v1.0 no
101 fexth 6.0(2)N2(7) 7.0(1)N1(1) yes
102 fexth 6.0(2)N2(7) 7.0(1)N1(1) yes
103 fexth 6.0(2)N2(7) 7.0(1)N1(1) yes
1 microcontroller v1.0.0.2 v1.0.0.2 no
But I'm getting the error message
then the upgrade aborts.
Any advice please
Solved! Go to Solution.
10-02-2015 12:25 PM
The reason or the error is because you are using different kickstart and system image
kickstart is for 7.1.1 (n5000-uk9-kickstart.7.1.1.N1.1.bin)
System is for 7.0.1(n5000-uk9.7.0.1.N1.1.bin)
try using the same image for the upgrade.
-Raj
10-02-2015 10:31 AM
XXXXXXXXXX# sh ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2015, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
BIOS: version 3.6.0
loader: version N/A
kickstart: version 6.0(2)N2(7)
system: version 6.0(2)N2(7)
Power Sequencer Firmware:
Module 1: version v7.0
Module 2: version v1.0
Module 3: version v1.0
Microcontroller Firmware: version v1.0.0.2
SFP uC: Module 1: v1.1.0.0
QSFP uC: Module not detected
BIOS compile time: 05/09/2012
kickstart image file is: bootflash:///n5000-uk9-kickstart.6.0.2.N2.7.bin
kickstart compile time: 4/28/2015 5:00:00 [04/28/2015 13:37:44]
system image file is: bootflash:///n5000-uk9.6.0.2.N2.7.bin
system compile time: 4/28/2015 5:00:00 [04/28/2015 15:53:45]
Hardware
cisco Nexus 5596 Chassis ("O2 48X10GE/Modular Supervisor")
Intel(R) Xeon(R) CPU with 8253868 kB of memory.
Processor Board ID FOC193605N5
Device name: XXXXXXXXXXX
bootflash: 2007040 kB
Kernel uptime is 0 day(s), 0 hour(s), 40 minute(s), 34 second(s)
Last reset at 148358 usecs after Thu Jan 15 16:47:02 2009
Reason: Disruptive upgrade
System version: 6.0(2)N2(2)
Service:
plugin
Core Plugin, Ethernet Plugin
10-02-2015 10:33 AM
Show module
Mod Ports Module-Type Model Status
1 48 O2 48X10GE/Modular Supervisor N5K-C5596UP-SUP active *
2 16 O2 16 port flexible GEM N55-M16UP ok
3 0 O2 GEM with L3 ASIC N55-M160L3-V2 ok
Mod Sw Hw World-Wide-Name(s) (WWN)
1 6.0(2)N2(7) 1.1 --
2 6.0(2)N2(7) 1.0 --
3 6.0(2)N2(7) 1.0 --
Mod MAC-Address(es) Serial-Num
1 8c60.4faf.de88 to 8c60.4faf.deb7 FOC193605N5
2 8c60.4f6b.26f0 to 8c60.4f6b.26ff FOC19278J04
3 0000.0000.0000 to 0000.0000.000f FOC19289KJX
10-02-2015 12:25 PM
-Raj
