02-14-2018 05:28 AM - edited 03-01-2019 08:43 AM
we have confgured a basic vPC Cluster with two Nexus 5672UP and Version 7.1(0)N1(1b).
Spanning Tree priority is on both switches the same.
Problem:
Several SVIs with HSRP v2 are configured but HSRP neighborship doesn't come up. On the log we saw the following:
2001 Sep 16 16:01:20 xxxxxx %ARP-3-DUP_VADDR_SRC_IP: arp [3819] Source a
ddress of packet received from 0000.yyy.xxxx on Vlan666(port-channel10) is dupl
icate of local virtual ip, 10.17.22.1
It seems to be both switches saw the HSRP VIP as a duplicate IP from each other. HSRP config is basic:
interface Vlanxxx
no shutdown
no ip redirects
ip address 10.0.x.x/22
hsrp version 2
hsrp 1
priority 120
ip 10.0.x.1
ip dhcp relay address y.y.y.y
Can anyone support or know a solution here?
Udo
Solved! Go to Solution.
02-21-2018 09:50 AM
02-14-2018 09:59 AM
02-15-2018 02:09 AM - edited 02-15-2018 02:09 AM
here ist the output of show interfaces brief:
IP Interface Status for VRF "default"(1)
Interface IP Address Interface Status
Vlan1 10.0.x.2 protocol-up/link-up/admin-up
Vlanxxx 10.x.y.2 protocol-up/link-up/admin-up
Vlanyyy 10.z.y.2 protocol-up/link-up/admin-up
VLAN Interface Switch1:
interface Vlan100
description XXX
no shutdown
no ip redirects
ip address 10.x.y.2/23
hsrp version 2
hsrp delay reload 300
hsrp 100
preempt delay minimum 60
ip 10.x.y.1
ip dhcp relay address 10.0.x.yy
switch2:
interface Vlan100
description XXX
no shutdown
no ip redirects
ip address 10.x.y.3/23
hsrp version 2
hsrp 100
ip 10.x.y.1
BR
02-15-2018 06:25 AM
02-15-2018 06:30 AM
02-15-2018 06:36 AM
I have rebuild the configuration and also make on both switches a reload. Nothing works...:-(
Now I'm going to be make an update to the recommend version 7.1(4)N1(1).
02-15-2018 10:50 AM
02-15-2018 10:00 PM
I test this configuration on VIRL NXOSv and it's the same behavior..:-(
Version: 7.3(0)D1(1)
02-15-2018 10:38 PM
Weird. Let me see if I can lab it up.
02-21-2018 06:13 AM
Problem is solved. The base license was not available.
02-21-2018 09:19 AM
02-21-2018 09:38 AM
Yes, that has never happened to me before. Especially since the base license is actually included as standard. You can not order the switch without this license.;-)
02-21-2018 09:50 AM
02-21-2018 10:19 AM
