Nexus 5600 import map filtering route target extended community attributes
p-smallwood
I know that the Nexus 5600 can use match ip address to filter routes that are imported/exported from/to a VRF. Nexus 7000 can also match and set route target extended community attributes to enhance this import/export map filtering capability but does that also work on the Nexus 5600? The relevant 5600 config guide does not mention the capability.
0 Replies 0
