Nexus 7004 with N2K-B22HP-P FEX won't connect
netwerkbh
Hello
I'm trying to connect an HP Blade server with an N2K-B22HP-P to our Nexus 7004 but it stays in de download mode.
# sh fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
116        FEX0116        Image Download         N2K-B22HP-P   FOCxxxxxxxx
# sh fex detail
FEX: 116 Description: FEX0116   state: Image Download
  FEX version: 5.2(1)N1(1a) [Switch version: 6.1(4)]
  FEX Interim version: 5.2(1)N1(1a)
  Switch Interim version: 6.1(4)
  Module Sw Gen: 12594  [Switch Sw Gen: 21]
pinning-mode: static    Max-links: 1
  Fabric port for control traffic: Eth3/44
  Fabric interface state:
    Po116 - Interface Up. State: Active
    Eth3/44 - Interface Up. State: Active
  Fex Port        State  Fabric Port
Logs:
08/07/2013 18:04:24.424401: Requesting satellite to download image
08/07/2013 18:04:46.442690: Module register received
08/07/2013 18:04:46.443233: Registration response sent
08/07/2013 18:04:46.443516: Requesting satellite to download image
08/07/2013 18:05:10.475657: Module register received
08/07/2013 18:05:10.476109: Registration response sent
08/07/2013 18:05:10.476390: Requesting satellite to download image
08/07/2013 18:05:36.703639: Module register received
08/07/2013 18:05:36.704118: Registration response sent
08/07/2013 18:05:36.704434: Requesting satellite to download image
08/07/2013 18:06:04.741774: Module register received
08/07/2013 18:06:04.742505: Registration response sent
08/07/2013 18:06:04.742628: Requesting satellite to download image
Steve Fuller
Level 9
Level 9
Hi Martin,
At this point in time the N2K-B22-HP FEX is not supported with the Nexus 7000 series switches as the parent switch. If you look at Table 2 in the Cisco Nexus B22 Blade Fabric Extender Data Sheet you'll see it only lists the following:
Cisco Nexus parent switch model or line card
  • Cisco Nexus 5010 or 5020 Switch for Cisco Nexus B22HP and B22F
  • Cisco Nexus 5548P Switch
  • Cisco Nexus 5548UP Switch
  • Cisco Nexus 5596UP Switch
  • Cisco Nexus 6001 Switch
  • Cisco Nexus 6004 Switch
amey.dixit
What procedural steps you done while an HP Blade server with an N2K-B22HP-P to Nexus 7004??
Steve Fuller
Level 9
Level 9
Hi Martin,
