894
james21970
Beginner
Nexus 7k CMP Attach Issue
Hi all,
We are running serveral 7k installs, all redundant, and I have a problem with one particluar switch. After issuing the 'attach cmp' command, the returned characters are unreadable. It is just spitting out a bunch of jibberish, although you can tell that you are at a login prompt, and I can login, and tell approx where i'm at on the CLI. I can use the ~, to exit, and sometimes when I try to connect, it will just drop my connection.
Anybody seen this type of behavior?
1 REPLY 1
prasad.gsmc
Beginner
Not seen before. but CMP could be configured for SSH as well.
if you want to attach, try with a different terminal emulator like secure CRT etc
