02-10-2018 11:30 AM - edited 03-01-2019 08:43 AM
Hi guys,
I am on my way of replacing two classy IOS HSRP enabled core SWs with two Nexus 9372.
I vPC on both along with vPC peer link and vPC peer-keepalive link.
Next I connected all uplinks from access switches (pure L2 SWs) to each Nexus and used vPC for each.
show run vpc
version 7.0(3)I4(7)
feature vpc
vpc domain 102
peer-keepalive destination 5.5.5.1 source 5.5.5.2 vrf pkal
delay restore 150
peer-gateway
interface port-channel3
vpc 3
interface port-channel9
vpc 9
interface port-channel10
vpc peer-link
So far, so good. Today I have shutdown all SVIs on the standby IOS HSRP switch and added Nexus_2 switch as standby HSRP switch.
Here come my issues:
1. I can't ping from Nexus_2 any connected device within a SVI.
Let's take SVI 610:
ping 172.16.11.129 aka the IP from ISP1 (see the diagram); obviously ISP1 and ISP2 run HSRP between them
PING 172.16.11.129 (172.16.11.129): 56 data bytes
Request 0 timed out
Request 1 timed out
^C
--- 172.16.11.129 ping statistics ---
3 packets transmitted, 0 packets received, 100.00% packet loss
show ip arp vlan 610
Flags: * - Adjacencies learnt on non-active FHRP router
+ - Adjacencies synced via CFSoE
# - Adjacencies Throttled for Glean
CP - Added via L2RIB, Control plane Adjacencies D - Static Adjacencies attached to down interface
IP ARP Table
Total number of entries: 1
Address Age MAC Address Interface
172.16.11.129 00:03:19 0000.0c07.ac01 Vlan610
ping 172.16.11.129
Request 0 timed out
interface Vlan610
description --- Data segment ---
no shutdown
ip address 172.16.11.141/28
hsrp 61
preempt delay minimum 15
priority 105
ip 172.16.11.142
track 7
Two mentions:
Nexus_2 acts as vPC secondary:
show vpc brief
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 102
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : failed
Type-2 inconsistency reason : SVI type-2 configuration incompatible
vPC role : secondary
Number of vPCs configured : 7
Peer Gateway : Enabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Disabled
Delay-restore status : Timer is off.(timeout = 150s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
vPC Peer-link status
id Port Status Active vlans
1 Po10 up 1,3,5-7,10,13,20-21,30,32,40,42-43,50-51,55,60,65,
70,75,80-81,90,104,110-111,115,120-122,125,160,200
-203,208-211,215,218,220,249,288,505,507,555,560,6
00,605,610,615,620,630,777
and there's no SVI for vlan 610 on Nexus_1.
I noticed if I enable vlan 610 on Nexus_1 then ping does work, still I am not 100% why? Is it how control plane on Nexus_2 handles packets?
I'll post my 2nd and 3rd issue after we get this 1st one.
Florin.
02-10-2018 04:56 PM
Nexus switches don't work anything like other switches. I highly doubt you'll be able to get them to join another HSRP group. With Nexus both switches in a vPC group process packets. There isn't really a standby, more of an active/active. They also wont usually forward traffic over the vPC link, and it is really easy to get caught out with a design that works in the Catalyst world that wont work in the Nexus world.
Have a quick look at this:
And note these restrictions:
02-10-2018 10:30 PM
Hello Filip,
Thanks for the follow-up. As we speak HSRP worked without any issues.
But I can't say the same about ICMP. Now assuming ICMP is being hindered by that vPC rule, how come when I enable SVI on Nexus_1, all of a sudden Nexus 2 can ping ?
02-11-2018 12:31 PM
02-12-2018 12:29 AM
Hello Rick,
Thanks for the follow-up. Obviously I am using same HSRP group ID. Still my current issue/question stands out:
- why ICMP is not working?
- let's say because traffic IS NOT sent over peer-link, OK. Then what changes when I enable same SVI ID on Nexus_1; how come then traffic is being sent over peer-link?
P.S. I agree my setup lacks some recommendations as you said, still I think it should've worked. As far as I read 9k documentation I did not met my topology as being NOT supported.
02-13-2018 01:32 AM
HSRP is rather different in Nexus implementation, but it should work in this case. Remember that HSRP in nexus is acts as active-standby just in the control plane, but in the data plane is active-active.
I think the problem here is related to the peer-gateway activated on the vpc, which instructs the switches to respond to the other vpc switch mac address. In this case Nexus 1 is consuming the packets destined for Nexus 2.
Try to exclude the vlan from peer-gateway:
peer-gateway exclude-vlan [123]
Georgian
02-13-2018 01:33 AM
Georgian
