Highlighted
Beginner
Nexus 9500 Max Amperage Consumption
Hello, I want to find information about the max electric current consumption of the Nexus 9500, I have 20 amps destinated for that equipment, I want to know if that is enough? Please send me a URL with that information.
Thanks for all the help.
Julio Guzmán
1 ACCEPTED SOLUTION
Beginner
Re: Nexus 9500 Max Amperage Consumption
Thanks. I watched the watts consumption for my power supplies.
The current in amps (A) is equal to the power in watts (W), divided by the voltage in volts (V), for those power supplies I can work with 20 A fine.
JG
Contributor
It all depends on what module you buying along with N9K.
check below document will help you.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/solution-brief-c22-730049.html
BB
BB
*** Rate All Helpful Responses ***
Beginner
JG
Ask the Expert- Webex Hybrid Services Solutions
