hello together,
on my nexus 9372 monitor session is set to both but the switch only sends out tx packets instead of both rx and tx
!Command: show running-config monitor
!Time: Fri Jan 18 12:28:48 2019
version 7.0(3)I2(2a)
monitor session 1
source interface port-channel1 both
destination interface Ethernet1/38
no shut
sh monitor session 1
session 1
type : local
state : up
acl-name : acl-name not specified
source intf :
rx : Po1
tx : Po1
both : Po1
source VLANs :
rx :
tx :
both :
filter VLANs : filter not specified
source fwd drops :
destination ports : Eth1/38
port-channel1 is up
RX
2113 unicast packets 310 multicast packets 0 broadcast packets
2423 input packets 251758 bytes
TX
2423 output packets 250704 bytes
Ethernet1/38 is up
TX
2165 unicast packets 318 multicast packets 0 broadcast packets
2483 output packets 257756 bytes
as you can see on port eth1/38 there should be ~4300 unicast packets. in wireshark i also dont see packets from this switch, only the answers. same behaviour on another nexus 9k. what am i doing wrong
