08-28-2012 03:51 AM - edited 03-01-2019 07:09 AM
Is ISSU the only way to upgrade a Nexus 5K and 7K platforms? Is there a non-ISSU way of upgrading the nexus? Appreciate any help.
Thank,
Mohan
Solved! Go to Solution.
08-28-2012 06:34 AM
You can change the boot variable and reload. However, ISSU (or install all command) is recommended due to the fact that it will perform multiple check (validate image, check platform firmware, etc.).
HTH,
jerry
08-28-2012 06:34 AM
HTH,
jerry
08-28-2012 08:39 AM
Thanks Jerry. This is what I was looking for.
Mohan
