Nexus Data Broker - Filter Odd Numbered Addresses
dperkerson
Good Day All!
Working on setting up a connection in a Nexus Data Broker but I need to split my traffic among multiple destinations. The application that we are running on the destination can only handle 5Gb of traffic at a time. We have less than 10Gb, but more than 5Gb. I'm looking to split the traffic between two destinations by sending odd IP addresses to one host and even IP addresses to another. I know how to split traffic this way using an access-list but there doesn't seem to be a way to provide an access-list to apply via the GUI. Since the GUI just creates access-lists to manage traffic, can I  add the access-list to the port manually or will that freak out the system. I would appreciate any feedback for trying to split this traffic between the two destinations, using the Nexus Data Broker.
Thanks!
xfyang
Hello
I have a similar case here:
(1)Adding an ACL via the CLI can cause problems, so we use the GUI to add it.
Here you can add a filter to copy the edited IP address information; we generally use any to destinations (select Bidirectional)
(2)Establish multiple connections on the GUI, and implement traffic splitting according
to different priority(the traffic can be split into different delivery interfaces through priority adjustment)
But I have another strange problem: After filtering, some TCPs have traffic out-of-order
              ##Do you have such a problem?
My system version and NDB version are:
   NXOS: version 7.0(3)I5(1)
   NDB: 3.2.2
