Nexus - port-channel load balancing
Manu Shankar
Beginner
Beginner
Port-channel   load balancing is a global command or interface command in Nexus switch?
Manu
Steve Fuller
Engager
Engager
It's a global command; port-channel load-balance ethernet.
You can find details in the Configuring Load Balancing Using Port Channels section of the Nexus 5500 Series NX-OS Interfaces Configuration Guide.
Steve Fuller
Engager
Engager
Thank you Steve. I was looking whether we able to configure the load-balancing method per port channel. Refering few Cisco docs I came to know that it is not possible.
