02-27-2017 04:11 AM - edited 03-01-2019 08:30 AM
Hi All,
Please share your experience and experties if possible Nexus switch can be use for authentication through ACS and Local username Database at a time.
Solved! Go to Solution.
03-05-2017 07:04 AM
I don't think you can do two authentication at same time, either local first or fallback if ACS goes..
Normally , we design and implemented with fallback mechanism and never did with parallel authentication ...
Hope it Helps..
-GI
03-03-2017 02:46 AM
Hi All,
Have a look on the below link with ACS integration with Nexus Switches , hope that helps..
http://www.cisco.com/c/en/us/support/docs/security/secure-access-control-system/115925-nexus-integration-acs-00.html
https://supportforums.cisco.com/document/54611/configuring-acs-5x-authenticate-role-based-access-control-rbac-users-nexus-5000
Hope it Helps..
-GI
03-05-2017 06:00 AM
Thanks for your reply.
aaa authentication login default group ACS
But the above command is not type local (key word).How to authenticate with (Local and ACS database) in same time.
03-05-2017 07:04 AM
Hope it Helps..
-GI
