Nexus switch Transciever showing Unknown status
roycemathew
hi All,
I am having an issue with my Nexus 5548.
Switch: N5K-C5548P
SFP: SFP-H10GB-CU2M
SFP transciever showing unknown . Port is connected to another Nexus 5548. This interface is use for forming VPC peer link.
switch# sh int eth1/7 transceiver
Ethernet1/7
    transceiver is present
    type is 10Gbase-(unknown)
    name is CISCO-MOLEX
    part number is 74752-9642
    revision is 09
    serial number is MOC1833A4GQ
    nominal bitrate is 10300 MBit/sec
    Link length supported for copper is 2 m
    cisco id is --
    cisco extended id number is 4
Any help in understanding the issue will be great.
Akshit Dhingra
Hello
Is the link up ?
Do you see any errors or connectivity issues from  this link?
If not, then this might be just a cosmetic issue.
Akshit
Keny Perez
Level 8
Level 8
can you issue the same command but with the word "detail" at the end and post the output here?
-Kenny
