Nexus Upgrade 5.1.5 Pre-Upgrade check failed
alanjbrown
Beginner
Beginner
I'm looking to upgrade from 4.2.4 to 5.1.5 and after running the impact command got the following message:
show install all impact kickstart bootflash:///n7000-s1-kickstart.5.1.5.bin system bootflash:///n7000-s1-dk9.5.1.5.bin
Pre-Upgrade check failed. Return code 0x40930062 (free space in the filesystem is below threshold)
Does anyone know what this might mean? and how to resolve?
Secondly, the release document have been updated (6/10/2011) to show that there is an ISSU upgrade from 4.2.6 or 4.2.8 but no mention of 4.2.4.
Can anyone advise what's going to happen when I go from 4.2.4 to 5.1.5?
thks,
Al
11 Replies 11
alanjbrown
Beginner
Beginner
I have investigated further and found the following issue:
show system internal log install detail
check_freespace: /var/sysmgr total blocks: 262144, free blocks: 0, space being used: 100%
fsm_action_pre_verification: Free space in "/var/sysmgr" partition is below threshold: 80
show system internal flash
Mount-on                  1K-blocks      Used   Available   Use%  Filesystem
/var/sysmgr                 1048576   1048576           0    100   none
See
http://docwiki.cisco.com/wiki/Cisco_Nexus_7000_Series_NX-OS_Troubleshooting_Guide_--_Troubleshooting_Memory
I will look into getting this file cleared.
I have also run install check on another N7K and this shows non-disruptive upgrade from 4.2.4 to 5.1.5 however I would still like to see this confirmed.
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     2       yes  non-disruptive       rolling
     3       yes  non-disruptive       rolling
     4       yes  non-disruptive       rolling
     5       yes  non-disruptive         reset
     6       yes  non-disruptive         reset
     7       yes  non-disruptive       rolling
     8       yes  non-disruptive       rolling
thks,
Al
Hello Alan
Always refer to the Release notes as to what supported for ISSU and what not.
The version jump you want to do will be disruptive.
Refer to the notes
If you however want to stay within ISSU, upgrade to 4.2.8 first using ISSU and then upgrade to 5.1.5 using ISSU again. That should allow hitless upgrade.
hth
Hth,
Thanks for the feedback, although the install test says that the upgrade is non-disruptive, you and a couple of other contacts have said that the upgrade is disruptive.
The release notes don't explicitly mention 4.2.4 so the lesson here is if the release notes don't talk about your version then assume the worst and do a two stage upgrade.
We plan to upgrade in a couple of weeks and I'll post an update once finished.
Al
So I cannot say for certain that it would be disruptive. That does depend on the versions of code.
What is listed in the release notes, are not the only methods, but it  has been test by cisco, and therefor it is safe to assume this will not  cause downtime.
Look at this this way. Are you willing to risk downtime at the cost of customer experience, due to an uncertainty?
Doing a bunny hop upgrade will take you perhaps an extra 30-40 minutes. Is this really too much time for a hitless upgrade and no risk?
That is a business decision more than a technical decision.
hth
Ruhann,
We performed the upgrade at the weekend and it was non-disruptive however we did encounter some issues. After getting to 4.2.8, we ran the install to 5.1.5 and it was shown to be a disruptive upgrade.
     2       yes      disruptive         reset  Current running-config is not supported by new image
     3       yes      disruptive         reset  Current running-config is not supported by new image
Additional info for this installation:
_
Some features currently enabled are not available in the new image. Please use the 'show incompatibility-all system' command to obtain further information on what needs to be disabled in order to perform a non-disruptive installation.
show incompatibility-all system  bootflash:///n7000-s1-dk9.5.1.5.bin
Checking incompatible configuration(s) for vdc MYNEXUS:
The following configurations on active are incompatible with  the system image
1) Service : vpc , Capability : CAP_FEATURE_VPC_GRACEFUL_TYPE1_CHK
Description : vPC "graceful type1 consistency-check" is configured under "vpc domain"
Capability requirement : STRICT
Disable command : Remove "graceful consistency-check" config from vPC domain
show running-config vpc all
!Time: Sat Oct 22 14:09:57 2011
version 4.2(8)
feature vpc
vpc domain 20
  role priority 100
vpc domain 20
  role priority 100
It appears that when we upgraded from 4.2.4 to 4.2.8, the graceful consistency-check feature had been added by default. It was diffcult to get any details as all the documents seem to suggest this feature wasn't added until 5.2.
Anyway we removed the line of config and the upgrade continued non-disruptively to 5.1.5.
Al
hello Alan,
i have also a 100% filled /var/sysmgr, but i am not able to free some space, executing filesys delete command, i get a new error; eg:
filesys delete /var/sysmgr/work/core.3842
"Files are not supposed to be deleted from this directory"
if i look deeper in work directory, i will see a lot of core.XXXX files, thinks this are dump files about 50MB each.
sh system internal dir /var/sysmgr/work
        ./         740
                                                               ../         300
                                                        core.6014            0
                                                        core.5996            0
                                                        core.5984            0
                                                        core.5927            0
                                                        core.5921            0
                                                        core.5860            0
                                                        core.5838            0
                                                        core.5836            0
                                                        core.5362            0
                                                        core.5310            0
                                                        core.5308            0
                                                        core.5306            0
                                                        core.5290            0
                                                        core.5286            0
                                                        core.5282            0
                                                        core.5280     33574912
                                                        core.5281     26292224
                                                        core.5239     55975936
                                                        core.5237     55975936
                                                        core.5221     55975936
                                                        core.5211     55975936
                                                        core.5198     55975936
                                                        core.4832     55975936
                                                        core.4830     55975936
                                                        core.4822     55975936
                                                        core.4820     55975936
                                                        core.4790     55975936
                                                        core.4788     55975936
                                                        core.4724     55877632
                                                        core.4723     55877632
                                                        core.4721     55877632
                                                        core.4722     55877632
                                                        core.4672     55881728
                                                        core.4576     55877632
                                                        core.3842     54665216
do know how to delete this files?
theres is no help on the filesys command, due to it is hidden!!!
reload has been already done, but this does not free space!
thx in advance, best regards
Thomas
Thomas,
This was some time ago but I've been through some old mail and found this response.
"TAC have a plugin to access the kernel which they can use that clears out the files without having to reboot the switch. These are non essential files that would be cleared if the switch was rebooted anyway."
I guess your next step is to contact TAC and get them to remove the files.
Alan
S Vivek Iyer
Beginner
Beginner
Hi Alan,
I also ran into this same issue. Was checking the blog and found this one.
Error:
xxxxxxxxxx# sh install all impact kickstart m9100-s2ek9-kickstart-mz.5.0.7.bin system m9100-s2ek9-mz.5.0.7.bin
Pre-Upgrade check failed. Return code 0x40930062 (free space in the filesystem is below threshold).
check_freespace: /var/tmp total blocks: 38400, free blocks: 11038, space being used: 71%
fsm_action_pre_verification: Free space in "/var/tmp" partition is below threshold: 70
/var/tmp                     153600    109448       44152     72   none
/var/sysmgr                  153600      5948      147652      4   none
Was trying to list internal Dir files. but seems those commands dont support in 9124 model .
Getting error.  As "Invalid Commad"
In Cisco NX-OS release 4.2(4) and later releases, use the following  commands to display and delete the problem files from the CLI:
The show system internal dir full directory path command lists all the files and sizes for the specified path (hidden command).
The filesys delete full file path command deletes a specific file (hidden command).
NoteNote: Use caution when using this command. You cannot recover a deleted file.
Is there any other way apart from reboot , we can correct it..
Vivek
grant.maynard
Enthusiast
Enthusiast
i don't know whether you resolved your problem but i do know you can get "free space in the filesystem is below threshold" errors when attempting upgrade if the Nexus has not been rebooted since first config. This clears /var/tmp.
N5548# show system internal log install detail
<Fri Feb 27 11:53:27 2009> check_freespace: check_freespace: /var/tmp total blocks: 76800, free blocks: 29874, space being used: 61%
<Fri Feb 27 11:53:27 2009> fsm_action_pre_verification: fsm_action_pre_verification: Free space in "/var/tmp" partition is below threshold: 10
N5548# show system internal flash
/var/tmp                     307200    187704      119496     62   none
/var/sysmgr                 1024000     20196     1003804      2   none
N5548#
Not sure what problem was in switch , reboot worked for me.
jkukunuru
Beginner
Beginner
I have received the same error on Nexus 3548s. Tried to execute " filesys delete......" command but it looks like we cannot do that on 3ks. I have read somewhere online that TAC will be able to help clearing those files but we didnt have support plan. So I did the classic trick - reload the switch. After the reload, when I installed the images, everything worked fine!
Recognize Your Peers
