Nexus9000 C9272Q chassis | QSA support
georgip
Hello all,
I have a N9272Q and want to downgrade the 40G ports to 10G using the SFP+ Adapter (QSA) Module.
Link is up/up on the other side of the connection but "notconnected"
Ethernet1/31
    transceiver is present
    type is QSFP-Cazadero
    name is CISCO-DNI
    part number is CAZADERO-R
    revision is 03
    serial number is DTY204601DN
    nominal bitrate is 10000 MBit/sec per channel
    cisco id is 13
    cisco extended id number is 155
(config-if)# speed-group 10000
ERROR: Ethernet1/31: Configuration does not match the port capability.
(config-if)# speed 10000
Speed is 10G, but the port doesn't support this speed
My question is -- is this supported configuration or breakout cabling is the only option to go?
Many thanks,
-vmrv.
