NFVIS API | VNC Console start API call
Evgeniy_Butakov
I'm trying to start VNC console using REST API on NFVIS.
According to NFVIS API reference you have to do POST request to  /api/operations/vncconsole/start without payload, which obviously doesn't make sense as host might have multiple VNF deployed and without payload we cant specify to which VM we would like to have a VNC console. As expected host returns HTTP 400 response which means Bad Request. Could anyone provide me with correct uri/payload to open VNC console?
Thanks.
Evgeniy
Evgeniy_Butakov
Solution has been found.
json payload should be
{"deployment-name": <put deployment name here as string>, "vm-name": <put vm name here as string>}
 works on NFVIS 4.7.x, but doesnt work on 3.12
Please note that API call doesn't return VNC port number as I think it should, but you can connect to port 6001 at first call. With every subsequent call port number is incrementing by 1(6001, 6002 etc)
VNC URL is https://<ip>:<port>/vnc_auto.html
