no FCoE Commnads
ronanphelan
HI All
I have enabled installed and Eval licnese and enabled FCoE on a nexus 5548 however I dont have the expected fcoe subcommands
when i run fcoe ? i get the following:
*** No matching command found in current mode, matching in (config) mode ***
  fcf-priority    FCF priority specification
  fcmap           FC MAP specification
  fka-adv-period  FKA Advertisement Period
  veloopback      VFID check for VE port
here is my sh run
!Command: show running-config
!Time: Sun Feb  1 06:32:43 2009
version 5.2(1)N1(6)
feature fcoe
hostname TK5-145-5548
feature npiv
feature fport-channel-trunk
no feature telnet
cfs ipv4 distribute
cfs eth distribute
feature lacp
feature vpc
feature lldp
Have i left something out as i cant configure my ports as fcoe hence cannot see anything in the flogi database
Many thanks
Ro
Hi Mike
Thanks for the info but I soon realised I was using the incorrect cli
configuration guide
ro
Sent: 28 April 2014 20:27
To: Ronan Phelan
Subject: Re: - no FCoE Commnads
Cisco Communities <https://communities.cisco.com/>
no FCoE Commnads
reply from Michael Turner
<https://communities.cisco.com/people/micturne>in *Technology
Data Center & Cloud* - View the full discussion<https://communities.cisco.com/message/151834#151834>
micturne
Level 4
Level 4
Hello Ro,
I received the following reply:
"In case you still have this problem, you are just doing the configurations in the wrong place, maybe inside an Ethernet port so you get that message.
You might want to take a look at this:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/fcoe/521n11/b_5k_FCoE_Config_5...
and this:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/san_switching/521n11/b_5k_SAN_...
The configuration is being entered in the wrong place. They need to check the configuration guides."
Please let us know if this helps.
-Mike
Hi Mike
configuration guide
ro
To: Ronan Phelan
no FCoE Commnads
Thanks for the update Ro.  I'm glad you got it figured out.
-Mike
