07-28-2013 03:37 AM - edited 03-01-2019 07:22 AM
HI Guyz,
I am Designing a OTV Topology, where i have M1 series card (N7K-M108X2-12L) in OTV VDC & F2 Series card (N7K-F248XP-25E) in Aggregation VDC.
I need to connect M1 interface as its OTV INTERNAL interface to F2 interface in Aggregation VDC to learns local mac-addr.
i will dual hommed M1 interfaces from OTV VDC to 2 different 7K aggregation VDC using VPC.
as shown in fig Link-3 & 4 will be vpc member ports for 7K-A , 7K-B.
Are there any Limitations for connecting M1 interface direcltly to F2 interface , as shown above OTV VDC M1 port connects to Aggn VDC F2 port.???
thanks,
Mazhar
01-28-2014 10:11 AM
Can anyone weigh in on this? I have the same question. What is the best practice, mix F2e ports with M1 ports in OTV VDC or keep M1 only ports in OTV VDC?
01-29-2014 05:37 AM
The only requirement to deploy OTV is the join interface must be in the M-module or F3 module (not avaliable for Nexus 7000 platform yet, only Nexus 7700).
The OTV internal interface, can be a M1 or even F-card in the lastest release.
About mix F2e with M1 modules, when you do that, the F2e routing capability is disabled, so all routing decision will be proxied to the M-module. This routing capacity is limited by the quatity of ports M that you have in your VDC.
